LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
KatoKato's Avatar
Question 3.2 Exhaust Modification
Hello,
I'm planning on installing a cat. bypass pipe and cone air filter on my stock 3.2L engine.
Would this also require a change in the DME chip so I don't destory my engine in the process?
Thanks for your help,
Old 01-04-2005, 11:46 AM
Somewhere in the Midwest
MotoSook's Avatar
I don't think you'll destroy the engine running a stock chip with a cone filter and pre-muffler, but you will leave a few HP's out in the ether w/o a tuned chip.
Why do you want a cone filter? The stock one flows fine.
Old 01-04-2005, 11:48 AM
KatoKato's Avatar
Cone filter mainly for aesthetics. Makes that part of the engine compartment much less cramped.
Is a pre-muffler the same as a cat. bypass pipe?
Thanks for the input,
Old 01-04-2005, 11:58 AM
bigrubberjeep's Avatar
Look into the Euro premuff that "looks" like the stock one, it will help you pass the visual part of a smog test. Then again, your in Canada. Do you have smog laws over there?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 01-04-2005, 12:07 PM
don911's Avatar
I recommend the Dansk pre muffler over the fabspeed. I've had both and like the dansk better.
No problem with the stock chip with a cat bypass/pre muffler. I agree with Souk on the cone filter issue.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 01-04-2005, 12:09 PM
MotoSook's Avatar
A cat by-pass is just a straight pipe. A pre-muffler has a chamber with a perforated "liner." The pre-muffler is quieter, and it's suppose to give 8-12 HP over the cat. I'm sure there is some gain with the by-pass pipe, but no one has quantified it...that I know of. It's likely to be very close behind the pre-muffler.
I made my own pre-muffler recently that is even quieter than the Danks or Fabspeed pre-muffler. It has a very throaty sound at idle and filters out the tinny sound of a 911 across the RPM range. I have to wait for warmer weather for performance testing.
Old 01-04-2005, 12:10 PM
Send a message via AIM to NoLift911
BTDT--
Not that those mods are a waste on their own - but a strong argument could be made that without a chip you would see minimal gains if any - other than sound.
Unless the engine space is of a huge concern save yourself some money and remove the horn and drill a few holes in the cover. I made a cup style airbox out of my lid in 5 minutes using a table saw. The sound is awesome accelerating in the upper RPM ranges.
Mods need to be done as a package in order to take full advantage of what you spend for them.
DME (Steve Wong)
Free flowing exhaust (Dansk)
Airbox mod (Drill holes or just use cut frame)
Cat-by pass (Fabiani)
The 3.2 will respond favorably to these modifications for a small amount of money.
-Jeff
Jeff
Old 01-04-2005, 12:17 PM
Originally posted by nolift911
BTDT--
DME (Steve Wong)
-Jeff
I agree 100% for sounds, the airbox mod is the best and least expensive.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 01-04-2005, 12:29 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
where are you all cutting the holes in the airbox? does any body have a picture? I have a 3.2 and am interested in freeing up some horsepower.
waiting on a chip and want to do some exhaust modifications.
was also thinking about removing the airbox and going to a mass air flow type from autothority.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-04-2005, 01:04 PM
MotoSook's Avatar
Cutting holes in the airbox is only for an audible gain...no HP gain. The MAF "upgrade" is little to no gain.
You want a change...get a pre-muffler, muffler and a Steve Wong chip.
Old 01-04-2005, 01:12 PM
just me
paulgtr's Avatar
steve wong? what's the difference betyween his and other folks' chips?
I have been planning to go to b&b headers, but have been told they are of no use on a stock 3.2, is that right?
Old 01-04-2005, 01:15 PM
Oh Haha's Avatar
Hey KatoKato,
I told you these guys would give you more info than you take in!
He and I have been PMing like mad trying to help him out with his wants vs. what will be most cost effective and maybe pass smog testing.
I have an SC so I didn't need to worry about any chips. i told him he needs to be aware of a possible lean condition when changing the exhaust from totally stock.
You all with the DME cars will be more help than me.
Thanks,
Wayne
Pacific Blue
Wayne
Old 01-04-2005, 01:20 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
search steve wong and this board and see what comes up.
74 911s neverending story. two feet and a jetta for now.
Old 01-04-2005, 01:21 PM
MotoSook's Avatar
I know someone who had a BB exhaust system on his very clean 3.2 and he sold it all! He went back to the stock headers with a pre-muffler and Steve's chip.
Search "Steve Wong" and you will have plenty to read.
Old 01-04-2005, 01:23 PM
coupla things:
- don't jsut drill the air box cover...completely section it...saw off the lid to only allow a "band" with the clips to remain, so it holds on the filter element properly. Frees up a lot of space. A la "cup" lid.....
- euro premuff will gain 6-8 hp. Straight through pipe is closer to 0 hp gain( say 0-3). Bruce Anderson's book talks a bit about this...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-04-2005, 01:27 PM
Wavey's Avatar
No *****.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 01-04-2005, 01:29 PM
MotoSook's Avatar
Wil: it's been a long time since I read BA's book, and it was before I owned a Carrera, but if removing the restricton (cat) and adding a premuffler can gain 8 HP, one would think the by-pass pipe has some gain (allows for more free flow than with the cat). Can you quote BA? I don't have my book handy.
Edit: Dave, watch it...I might revoke some of my free Guinness offers! )
Old 01-04-2005, 01:34 PM
Right Wil - that is the best way to go
I think Bruce Andserson's book is good but a little misleading in terms of results if I remember correctly...
I would like to see this for a totally stock unmolested 3.2 84-89
Stock dyno run get a baseline.
Add DME get dyno result.
Back to stock then do airbox mod (I think I remember he said even without a filter this yielded little or nothing at all) get dyno result
Back to stock do muffler mod, get dyno result.
Back to stcok do cat-by-pass mod, get dyno result....
Then try them together sequentially and finally all at once.
He just kept dynoing things with other mods if I remember right which was confusing.
All that said I think without going to headers you leave roughly 5 hp on the table with the above mods in place...alone I have no idea as it was not done that way.
Clear?
-Jeff
Jeff
Old 01-04-2005, 01:40 PM
someone asked
Old 01-04-2005, 02:08 PM
Wavey's Avatar
Hey, I was just agreeing with you, pal. He'll definitely have plenty to read!
Old 01-04-2005, 02:17 PM
