What is this little bugger with an acid hole?
...and can I patch it up?
82 sc drivers side trunk,
Cheers,
Christian
Old 08-19-2013, 11:25 AM
Checked out
McLovin's Avatar
pump for the windshield washers
Old 08-19-2013, 11:30 AM
Banned
50 bucks brand new VDO washer pump
Pelican Parts - Product Information: 928-628-074-01-M82
Old 08-19-2013, 11:46 AM
Ah, thanks Mclovin. In that case I will patch it up.....
edit, and thanks d. In that case I will buy a new. Tubes are pretty stiff as well.
Old 08-19-2013, 11:47 AM
RETIRED
Joe Bob's Avatar
Pump....cheap. Check the lines with about 50psi. You'll likely need check valves and/or squirters.
2012 ML350 3.0 Turbo Diesel
Old 08-19-2013, 12:19 PM
