dcarlson's Avatar
lubicating clutch cable
'86, 915. Wondering how to go about lubing clutch cable and pedal cluster before considering replacement or rebuilding. Appreciate any comments.
'86 944
'86 911
07 cayman
Old 04-11-2013, 06:20 PM
howard freeman's Avatar
What is it doing,Squeaking,groaning or moaning?? Many times noises from the clutch come from the small bushing on the attachment point of the clutch cable clevis to the arm on the pedal cluster. Bushing is plastic & often completely gone. You must determine where the noise is 1st,then proceed with diagnosis and repair. I don't find many cables that need lube. narrow the noise down to the front or rear of the car,and report back.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 04-11-2013, 06:42 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you ask a motorcycle repair shop...they might have one of the old grease pressure injection gimmicks.
It goes over the end of the cable where the center wire comes out...and forms a seal around the outer sheath...and has a grease fitting on it.
The idea is to force grease up into the outer jacket all the way through the cable.
It used to be standard practice to do it once a year or so.
Bob
Bob Hutson
Old 04-11-2013, 11:32 PM
dcarlson's Avatar
It's coming from pedal area that is why I was asking about lubing cluster and cable- plus the shop it was recently in for something else listed this as something it needed - I do trust their judgement - so any insight from someone who has done this would be appreciated, thanks for your response
'86 944
'86 911
07 cayman
Old 04-12-2013, 05:36 AM
dcarlson's Avatar
Bob
pedal end or back end? got to eyeball both and see how junked up they are first
'86 944
'86 911
07 cayman
Old 04-12-2013, 05:40 AM
redstrosekNic's Avatar
It's probably your bushings groaning as previously mentioned. Do a rebuild of the pedal cluster (I would recommend bronze bushings), and I will bet your noise will go away.
Dustin
Old 04-12-2013, 05:42 AM
The rebuild isn't too bad to do. The hardest part is removing the old roll pin, then putting a new one in when the rebuild is complete.
Dustin
Old 04-12-2013, 05:43 AM
Recreational Mechanic
Nickshu's Avatar
You can try lubricating with a motorcycle tool, but I agree most likely it's the cluster and/or the helper spring at the transmission.
Honestly, just replace the cable, helper spring and rebuild the cluster and be done with it. Unless you know it has been done in the recent past, the car is almost 30 years old. At this point age is more of a factor than mileage.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 04-12-2013, 06:22 AM
83 Targa
I've heard that a louder exhaust with more HP will cover up the clutch spring/pedal noises.
Old 04-12-2013, 06:43 AM
Lol
Until the bushing at the clevis is completely gone, the pin wears through, then you have no clutch action...
Dustin
Old 04-12-2013, 06:52 AM
83 Targa
hmmmmm good it point but it will still sound good in neutral....no?
Old 04-12-2013, 06:56 AM
wolds's Avatar
Anyone out there have an opinion on if you should actually lubricate the cable itself? The cable has a nylon sheath which makes it slick by nature. I know that on most of the bikes I own lubricating these sheathed cables is not recommended as it attacts dirt and that only the end/pivot point needs a touch of grease to keep it from binding up and bending the cable which would cause it to fatigue and break. Warren.
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 04-12-2013, 07:35 AM
That's the spirit . Haha
Dustin
Old 04-12-2013, 07:38 AM
Some recommend white lithium grease, but I installed mine dry from fear of attracting dirt.
Dustin
Old 04-12-2013, 07:39 AM
wolds's Avatar
I did the same last year and the clutch is smooth and easy.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 04-12-2013, 07:58 AM
dcarlson's Avatar
OK, sounds like nobody has lubed the cluster or cable. Thanks anyway for related comments. As I said, I'm not going to rebuild or replace either at this time - just asking if anyone has added some lube to either with any success in eliminating squeek from the cluster area. Guess I'll just have to explore down there myself, clean it up a bit, and go with some white lithium grease wherever it looks like it might do some good. Thanks again and have a lovely.
'86 944
'86 911
07 cayman
Old 04-13-2013, 06:00 AM
LWJ LWJ is online now
When I put my new cable in, I pulled it out. Greased the heck out of it. Put it back together. Done.
Now my pedals? On the to do list.
Larry
Old 04-13-2013, 07:09 AM
dcarlson's Avatar
got at the floorboard today - overall pretty clean under there and this is original board - incredible shape for it's age IMO..used some white lithium grease spray and will see if it eases the squeaks a bit - noticed some improvement right away but we'll see if use gets it working a bit better. Can anyone tell me if this clutch pedal spring looks like it is installed/oriented properly?
'86 944
'86 911
07 cayman
Old 04-17-2013, 02:53 PM
^^^ Clutch spring is good to go.
Dustin
Old 04-17-2013, 03:01 PM
dcarlson's Avatar
great thanks.
'86 944
'86 911
07 cayman
Old 04-17-2013, 03:07 PM
