Am I missing a relay/fuse ? 87 Carrera with empty socket in engine fuse block
Just wondering... http://forums.pelicanparts.com/uploa...1366496259.jpg
You are missing nothing. Used to set the idle. May have other uses. I don't believe the idle set procedure is in the Bentley manual but it is in the Haynes. What you see is normal.
The relay for the missile launcher goes there. :-)
It's a test port. Running a jumper between 2 of the pins disables the idle correction so you can adjust the idle. |
No, but you have a fuse that needs to get straightened out :)
Test connector.
Used to set the idle set screw on the throttle body.
http://forums.pelicanparts.com/uploa...1366512467.jpg http://forums.pelicanparts.com/uploa...1366512524.jpg |
| All times are GMT -8. The time now is 05:44 AM. |
