LinkBack | Thread Tools | Rate Thread |
Gorilla
Looking for a shop near Tampa, FL with a frame bench (Celette or otherwise)
Took some measurements on my front suspension crossmember mount points and found the driver's side is pushed back ~15mm or so.
Can anyone here recommend a shop in the Tampa Bay area of FL that has a frame bench and can pull my '73 back straight? I did a search here and didn't come up with anything... perhaps my search terms were off. Thanks for the help! |
MBruns for President
Rick's European Performance has a celleste bench. 6720 114th Ave Largo, FL 33773-5417 Phone (727) 546-5347
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Gorilla
Hey Jeremy,
Yeah, come to think of it, I guess I knew they had a bench or two... problem is, last time I was there both had what appeared to be eternal projects on them with many parts/other cars blocking the way. I guess I can give them a ring and see what the deal is. Thanks! Jeremy |
Frame machine
Check with Ron at Superior Auto Body 727 525 7885 or Kieth Johnston (he worked for Rick's European for 18 years) I don,t have his # but he is in the Largo area and the shop used to be his name
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
