Simplified steps to dx no start?
I have not been able to start my 2.7 MFI. If I remember correctly you can test to see if you are getting a spark at the plugs by pulling one of the wires and holding it near the plug and watching for a spark while someone cranks the engine.
If I don't have a spark there at that point, can I pull the coil cable from the center of the distributor and hold it close to a ground on the engine and then watch for a spark? If I don't get a spark there, then I have a bad coil? Does this process sound like an quick and easy way to make a diagnosis of whether I am getting spark? I know I have fuel because I can hear the pump and I can smell it, and the engine turns over quite quickly. I haven't done anything to the car except let the car sit for 2 weeks getting ready for an oil change and brake flush. It ran fine previously. |
Sounds like you are getting fuel.
If you are not having a spark, try this: Quote:
CDI not something I am familar with. But I can see it next to the fuse box. I noticed I have a single red wire that goes from the fuse box to the CDI unit and another wire that is heavily wraped in electrical tape. When I switch the ignition to on position and I move the red wire, I can hear a click within the coil. So this is my problem because after I move the wire and go and try to start the car, it fires up right away. So I will have to see how is this wire connected to the bottom of the CDI unit and make it more secure.
In the fuse box I noticed slots for 3 fuses. I have the top 2, but the bottom one is missing. What does this missing fuse control? Thanks |
The red wire provides power to the CDI (Capacitive Discherge Ignition) box. The Black wire goes to the points in the distributor and when grounded, causes the box to discharge it's charged up capacitor to the coil via the blue/yellow wire. There should be a 3 prong connector that connects the wires to the CDI box.
You can see the wiring here: http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1973_CIS_Part2.jpg. The CDI box is item 9. The distributor is item 5 and the coil is item 6. One of the fuse slots if for the Sportomatic transmission. That is the missing one. |
carful there is high voltage at the coil wires (320v+-) it will knock your you-know-what right in the dirt
Without getting too specific, all internal combustion engines require air, fuel and a spark. Each has their circuit and circuit components. It helps to know how the system works so one can diagnose the system more accurately.
Lacking that knowledge, many attempt to repair by replacement. That sometimes works, but it can also become expensive, and one winds up with a bunch of spare parts. It's also not recommended due to a typical lack of sufficient funds to replace everything. No spark? Work backwards in that system until your diagnosis confirms a gap in the usual process. The ignition system has a mechanical as well as an electrical component. Electrically, the source is the battery; the end of the circuit is the spark to ground. There are circuit elements in-between, each dependent on the other (switches, circuit paths, CDI unit, distributor, points, etc.). A good technician should be able to assist if you don't have the patience or the time to learn it this time. Forum advice is good too if you understand the jargon and can follow and perform the suggested diagnostic, repair and confirm steps. Sherwood |
Sherwood |
Simple enough. I just want to replace the one wire, so I find no need to turn ignition on or crank the engine.
Thanks |
| All times are GMT -8. The time now is 03:40 PM. |
