-   -   Sell a SC motor complete or part out? (http://forums.pelicanparts.com/porsche-911-technical-forum/745823-sell-sc-motor-complete-part-out.html)
Mikey83835 04-21-2013 09:28 PM
I always wanted a really fast 911 and bought the basis, a '74 Targa with 930 bodywork, lightweight interior and some lightweight body parts, big bars, 9+10X17 Ruf wheels, etc, etc, and I was going to have my wrench install a 3.6 motor.
Has a SC motor now which I figured I could sell for almost half of the 3.6 conversion cost but turns out it has 3 broken head studs, so it's not going to be worth near as much, and finances are a consideration. But after looking over used SC parts prices at the Pelican "for sale" forum it looks as though it should be worth much more in parts, opinions? Do I need any special tools to get it apart?
I am a mediocre mechanic, probably about a C-, I believe motor has 55,000 miles, no serial number on the flange (I read that this indicates a factory warranty replacement motor) but motor does have all the good upgrades, Carrera tensioners, telescoping oil-return tubes, Turbo valve covers, pop-off valve, and Fabspeed airbox,
TIA for any expert advice:)
LakeCleElum 04-21-2013 10:32 PM
I shopped long and hard for an SC motor 2 yrs ago....
With your low miles, I would think you could get $3,000 to $3,500 w/o having to part it out..........That's what I would try to do..........
parting out and shipping is a real pain......I don't think you would be any better in the end?
Norm Faustino 04-21-2013 11:14 PM
Good advice from the man there,;) I would agree 100%
Mikey83835 04-21-2013 11:49 PM
I guessed that needing the head studs done it was worth $2k or so,
boyt911sc 04-22-2013 08:59 AM
Complete CIS engine.......
Mikey,
Please post pictures of the engine/motor you are selling. I'm interested but without seeing what you have it is difficult to make an offer. While you could probably get more money parting the engine, the time and effort involve might not be worth it for you. But the final decision is all yours. Sent you a PM.
Tony
Mikey83835 04-22-2013 10:12 AM
Originally Posted by boyt911sc (Post 7400480)
Mikey,
Tony
Sure, but let me wait until about 6PM PDT, I will have the sun shining into the garage then and can get a better pic, altho' not much to see, basic SC motor with the typical upgrades, does not smoke or leak oil, compression close to 180 all around,
Here are 2 pics of the car in the meantime
http://forums.pelicanparts.com/uploa...1366650694.jpg
http://forums.pelicanparts.com/uploa...1366650727.jpg
Dodge Man 04-22-2013 11:34 AM
Early or Late SC 3.0?
Good running SC motors with less than 100K miles usually sell pretty well. Is it an early US (78-79 big valve), late US (80-83 high velocity), or ROW (Euro big valve)? If the is no number then try to get some casting numbers for reference. More details could get you more $$$$. I got my 83 ROW from a totaled 83 ROW garage queen at Dc Automotive about 1 hour after it was removed. Paid more than $3500 but my motor came with a pedigree on mileage & condition. 3.6 in a 74 should be a fun ride. Cool Targa. :cool:
Mikey83835 04-22-2013 06:16 PM
Pics as requested, 2nd pic shows Carrera tensioner plumbing, in last pic, the oil leak is coming from the trans front seal according to my wrench,
http://forums.pelicanparts.com/uploa...1366679742.jpg
http://forums.pelicanparts.com/uploa...1366679762.jpg
http://forums.pelicanparts.com/uploa...1366679775.jpg
James Brown 04-22-2013 06:47 PM
well shoot, 2 grand off sounds about right, it will have to be rebuilt anyway and the CDI box and fuel filter/accumulator will fetch a few bucks. It looks pretty stock so it might sell quickly. the 3.6 is worth the extra cost, good luck
80-911SC 04-22-2013 06:47 PM
engine with oil leak and 3 head studs is considered by most a core ... If you are not very methodical I would not recommend taking it apart your self ... the 3.0 is a good engine why not have your wrench rebuild it and fix the head studs when its apart .. saves you from needing a body harness, brain etc from the "upgrade you want to do ....
I would think about it .. I have an 80 SC lightened up and its plenty fast up to a buck and a half ...
engine swap not as easy as some here make it seem ... Its not plug and play ... actually it is but you do more than plug it in ....
john walker's workshop 04-22-2013 06:59 PM
any running, not blown up "core" 3.0 is worth $3000. doesn't matter if the studs are broken. the case is worth $1000, crank, $1000+, heads $600, plus all the rest of the stuff is individually worth more than the remaining $400.
Mikey83835 04-23-2013 12:41 AM
That is what I am thinking, $400+ each for the p&c's, rods, exhaust, $200+ each for the distributor, cams, cam towers, fan/alt assy, etc, should end up with almost $5k, but it is of course more bother.....
