ganun's Avatar
Engine mount Washer orient
I put aftermarket rear mounts on the 87 Carrera and it seems to me the big washers on either side of the mount should be so that the lip curves AWAY from the rubber NOT into it i.e. like this )( not () pinching the rubber.
Any thoughts appreciated.
George
Old 04-30-2013, 06:01 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Good luck on that one... You'll get it from both side
If it was to be meant to be mount like )=( might as well use a cheap flat washer since the concave part going away from the mount is totally useless.
Who Will Live... Will See
Old 04-30-2013, 07:03 PM
kodioneill's Avatar
Factory installation is concave away from the mount. You want the rubber isolation from the mount to the body otherwise you defeat the purpose of the mount.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-01-2013, 04:37 AM
Hmmmm interesting. I put mine this way (=) because once I took an old mount I was going to throw away and put it in my hydraulic press and the center rubber part pushed out fairly easily. I think under hard acceleration they are under some pressure to separate as the engine 'squats', so I'd like the washers to catch the rubber before it pops out. But I'll try turning them around next time the engines out (soon... I pull my engine for valve adjustments).
Chuck.H
'89 TurboLookTarga, 351k miles
Old 05-01-2013, 05:27 AM
(man/dude)
Jonny042's Avatar
I had aftermarket mounts in mine and switched to factory genuine - the difference was night and day.... just an fyi.
I researched the orientation at one time, as mine were installed () which seemed wrong to me. I found out that )( was factory but at one time there was a TSB that advised turining them to () if customers complained about something.
I currently have my aforementioned factory mounts installed () but plan to try )( to see if there is a further improvement to the NVH inside the cockpit.
Old 05-01-2013, 05:56 AM
Recreational Mechanic
Nickshu's Avatar
Very interesting. Mine are (). I replaced the 4 mounts about 3 months ago and reinstalled them in the same () orientation. My car is stock with full service history showing no one ever touching the mounts. Wondering if I should switch them around to see what happens.
FWIW I installed the stiffer OEM Cabrio engine mounts and it was a huge improvement.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 05-01-2013, 06:14 AM
MConn's Avatar
Good Question - I just changed the motor mounts on my 88 coupe, and put the washers back like I found them (=), but it looked like the washers were cupped over the rubber, keeping the rubber from flexing.
Mike
The more I learn, the less I know.
Old 05-01-2013, 08:51 AM
