porsher
aston@ultrasw.c's Avatar
G50 clutch fork
We have a G50-01 (shortened) and a 95 993 motor.
To make a long story short, which of these configurations looks correct?
I am referring to the angle of the clutch fork as controlled by the height of the ears on the release bearing.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 05-12-2013, 07:28 AM
I think you are asking if the fork is properly fitted behind the ears on the TO bearing.
I vote for the top image being correct. You should be able to look in and see if the fork tines are "under" the TO bearing ears, but I don't remember if I tried looking before.
Sold: 1989 3.2 coupe, 112k miles
Old 05-12-2013, 08:07 AM
I believe with a new disc the top image is close. when the disc wears the slave push rod extends more and the fork moves closer to your second pic.
But when I try to picture what happens I may have my thinking reversed since it is a pull type pressure plate.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 05-12-2013, 08:27 AM
porsher
In both cases the fork is engaged behind the ears on the TO bearing.
Clutch disc is new.
79 928 Race Car
Old 05-12-2013, 09:14 AM
If the disc is new and is replaced with a worn one Which way will the lever move? If it moves away from the slave cyl then position #1 would appear correct. If it moves towards the slave then probably pos #2 would be.
1995 993 coupe
2012 Boss 302
Old 05-12-2013, 12:42 PM
Definitely #1. The slave cylinder rod extends out and pushes on the fork.
#2 looks like the fork missed or came off the release bearing groove.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-12-2013, 06:14 PM
porsher
Thanks for the advice, option #1 it is.
79 928 Race Car
Old 05-15-2013, 07:11 AM
Not so fast Obviously the pushrod extends and pushes against the fork. The problem will be which way does the fork move when the disc wears. The resting position of the fork will change with clutch wear.Does it move towards the slave with wear then pos 1 doesn,t have anywhere to go. If it moves away with wear then position 2 doesn,t leave any room for wear change.
1995 993 coupe
2012 Boss 302
Old 05-15-2013, 07:17 AM
