Hot start / Rough Idle on 1975 with 993 engine
I have a 1975 with a 993 engine. Wanted to ask you if anyonecould give me some advise on the following problems I am having:
1)On idle, the car is running with a bit of a misfire. However, once you press on the gas, full throttle, its runs excellent, seems like the power is greatest after 3000 rpm.
2)Also on cold starts (45 degrees and below), the engine starts, but stops right back up. I have to restart several times, keep gas pressed in order to keep it running, and its
3) Occasional on hots starts, the car hesitates. This is when I drive in traffic mostly. I changed the starter to a higher torque one, but did not help.
Basically, I have established the car is running very rich at all times (fumes). Is there anything I can do to improve the low, , speed city driving
The ECU is from the 993, no plug on it, I'm guessing its running on "open loop mode". Also no 02 sensors hooked up. The spark p
Old 10-28-2013, 09:35 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Code the DME for no O2 sensor if it isn't hooked up.
Then check for vacuum leak
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-28-2013, 10:10 AM
