-   -   16mm Sway Bar Bushing Question (http://forums.pelicanparts.com/porsche-911-technical-forum/746665-16mm-sway-bar-bushing-question.html)
metrod 04-26-2013 02:02 AM
Hi,
I have a 16mm Sway Bar on the rear of my 77 911S, Pelican say that the 16mm Bushings are No Longer Available so can anybody help in regards to an alternative?
I am assuming by common sense that the 15mm would be too tight and the 18 way too big!!
Nigel
moneymanager 04-26-2013 06:31 AM
Use the 15. File a bit to loosen it or just let it show a small gap. WIll work fine.
metrod 04-30-2013 04:22 AM
Sounds good thank you
