NASA instructor
bornrich's Avatar
Interior light delay - Cause?
When I open the door to my SC the interior light does not turn on right away. This happens on either door. Before I tear in this problem, anyone have a clue where I should start? Or is this just how they are supposed to operate?
TIA
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 07-16-2002, 10:52 AM
Not Quite Banned
Thomas Owen's Avatar
Remove the switch from the door hinge area and clean the contacts. It is not a sealed unit, and pretty lame from the start.
To remove it, pull off the round rubber seal and you will find a 10-12mm hex nut that you must turn ccw.
Good luck
Thomas Owen
1972 911T
1972 911S
Old 07-16-2002, 11:28 AM
don911's Avatar
My delay was caused by the rubber cover. A hole wears into the over and the switch pin pokes through. I just removed the rubber cover and the delay is gone. I'd try that first before removing the switch.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 07-16-2002, 11:45 AM
