How to disassemble brake pedal part ?
Before I break something.
How do you disassemble the aluminum part of the rod that pushes the cylinder in the master cylinder ?
It has a recess for a wrench and a hole, is this a threaded part ?
This part is from a 356, I know this is a 911 forum but has much more traffic and perhaps somebody can help.
Old 04-30-2013, 11:07 AM
frannyB's Avatar
Hi There,
Is that a set screw in there? Try cleaning it up a bit so you can see things a little better. Also, maybe try posting on Samba's 356 forum. Bruce over there will know.
What year is that off of? A,B,C?
Franny
White '86 Carrera Cab "Shamu"
Old 04-30-2013, 12:02 PM
It is not a set screw, it has a pin.
Old 04-30-2013, 12:08 PM
frannyB's Avatar
Do you have the shop manuals or the Elfrink manual?
I don't think it comes off... That flat spot is to allow you to turn the shaft relative to the connector on the other end.
Why do you want to remove it?
f
Old 04-30-2013, 12:31 PM
To clean and electroplate the rod.
Old 04-30-2013, 02:20 PM
