nicfranc's Avatar
Hose ID and Connection Question
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 04-30-2013, 08:15 PM
Vacuum line.
It doesn't go anywhere, because the 1980 version doesn't HAVE a vacuum line there!
Someone swapped a different WUR into your car at some point. I don't know enough to know whether it's an earlier or a later one.
For now, try to connect that to vacuum somewhere.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-30-2013, 08:58 PM
nicfranc's Avatar
No wonder ……….
I was looking through my Bentley and Wayne's books and could not figure it out.
I found it just laying in the engine bay tangled with some other hoses.
Car runs fine but I am trying to replace dried out hoses and eliminate anything I might not need.
Do I need a WUR ?
I do not drive the car in the winter. April thru October
I would like to delete the fresh air fan and get the engine compartment cleaned up.
What else can I ditch ?
I am keeping the AC because it actually works. Not that I use it much.
I prefer to go topless.
Thanks for throwing an eyeball on the mystery.
Old 04-30-2013, 09:29 PM
nicfranc's Avatar
WUR vent….
I have done some extensive reading and it appears it is a vent and does not have to be connected to anything. Supposed to keep out debris from the port.
That is peculiar.
Since I do not drive the car in the cold can the WUR be eliminated ?
It is not working.
I have to warm up the car before it will idle but i am ok with that I just start out driving easy and in 5 minutes it idles perfectly.
I want to delete all non essential components.
I started by removing the CAT and stock muffler and the car runs much better for it.
O2 sensor has also been removed.
Old 04-30-2013, 11:27 PM
