Clutch pedal issues
Posted already but since its the weekend I thought I would seek a few more opinions.
1988 CAB taken out of the garage from the winter and driven a week when the clutch pedal after shifting would intermittently not return to the top position.
I had to take my foot and come from the back and pull it up to wards the driver about 2 inches. Cable? Spring? something else?
Would appreciate the groups thoughts on where to start looking to fix this issue
Old 05-04-2013, 05:58 AM
Is it more likely to occur when the weather is cold, or right when you start driving, and then does not occur when things get warmed up?
If so, then its not a cable or spring - here is a similar thread: '87 Carrera Clutch Pedal Sticking
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 05-04-2013, 08:07 AM
muck-raker
kidrock's Avatar
bleeding the slave cylinder would be the first thing that I would do....but it's a real PITA because of accessability issues. Small hands, skinny arms and a lot of patience will go a long way with this job.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-04-2013, 09:26 AM
