Bigbartguy's Avatar
short legs - need clutch pedal help
I'm sure that I'm not the only one with this problem:
my legs are a little shorter and I have to pull the seat almost completely forward to allow me to fully engage the clutch.....not only does this put my face about 4 inches from the windshield, but it also causes big problems shifting into 2nd gear (lever hits the seat).
I would like to extend the pedal backward somehow and cant seem to find an extension to attach. I guess a wood block duct taped to the pedal would work...but doesnt sound very safe. Any ideas ?
(besides taking steroids or stretching my legs?)
please be kind.
Tim
1985 Targa - SOLD
1995 Cabriolet
Bigbartguy Gallery
Old 07-18-2002, 10:30 AM
Mark Wilson
Guest
Posts: n/a
One of the PO's of my first 911 had the same challenge. He drilled holes in the pedals and screwed wooden blocks to them. I only assume he attached the gripper/cover thingies for foot traction.
Mark
Old 07-18-2002, 10:42 AM
jabb's Avatar
Platform Sneakers
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 07-18-2002, 10:50 AM
Now let's be careful here and not poke fun at the "little people" here. He's asking a serious question. Personally I say "you gotta love them midgets".
Dan O
Old 07-18-2002, 10:55 AM
on the last one i did for a real short lady, i made a copy of the metal pedal pad from 1/4" plate, curved it like the original and spaced it out with a couple of pieces of tubing that bolts went thru. hang a pad on it and go.
206 637 4071
Old 07-18-2002, 11:01 AM
John Rogers's Avatar
I had this problem with my 914 race car after I installed a removable steering wheel and I added 1 inch thick lexan blocks under Sparco pedal attachments. You can see a picture (#21) in the article I have on how I setup my race car on the PP site here in the 914 section. You'll have to drill at least 2 holes for each pedal to bolt it all together, but it works great! Good luck.
Old 07-18-2002, 11:03 AM
Don Plumley's Avatar
I'm in the same camp - I like to call it "vertically challenged". I noticed at the Autox this last weekend that I was crowding the wheel just a little bit - and I like to sit more upright.
I'm planning on adding about 1/2" when I put aluminum track pedals on - I'll fabricate spacers out of aluminum stock or something. Might help with heel and toe too.
Don Plumley
M235i
Old 07-18-2002, 11:04 AM
MN
Sarah's Avatar
Hi Tim,
Just wanted to add that when my Tim sat in your car (and he is almost 6') he also had a stretch getting the clutch pedal pushed in completely.
Sounds like John Walker's suggestion could work for you.
Good luck!!
87 930 Blk/Blk
Old 07-18-2002, 02:44 PM
R22tech's Avatar
I'm confused....I'm no towering inferno and I can use the clutch just fine without having the seat way up. Are you sure your clutch is o.k? Maybe your seat's vertical adjustment is off or something? Mine is an 85 also, so maybe you ought to go sit in another of our vintage just to make sure your o.k. mechanically.
85 Carrera Targa (sold!)
03 Dodge Ram 1500 HEMI
Old 07-18-2002, 02:50 PM
Bigbartguy's Avatar
I've got the electric seats with the 2 adjustable switches and have tried a bunch of different settings. My clutch doesnt need to go all the way to floor to engage, but I prefer pushing it to floor just to make sure.
stats - 5'8"
165 lbs
21 " inseam
just kidding, 30" inseam. I'm going to add an metal extension on with bolts/nuts and back my seat up a bit........looks like I have a Saturday project now !
Tim
1985 Targa - SOLD
1995 Cabriolet
Bigbartguy Gallery
Old 07-18-2002, 05:03 PM
jabb's Avatar
I am your size drive an 84 ......
Is the floor board in place ?
Maybe there is no floor board and the clutch is ging down to far ....
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 07-18-2002, 06:04 PM
Got Boost?
IMONBOOST's Avatar
I have the same problem, I used a rubber sanding block from pepboys. Drilled a hole on the pedal and bolted the block with the curvature facing the driver.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 07-18-2002, 06:29 PM
Senior Member
Hello
Hint: Pre 76 pedals are adjustable from the factory. Mostly you can get some 20-30mm out or inwards.
Grüsse
Old 07-20-2002, 11:02 AM
I am glad someone else has to problem too, I have been adjusting the seat in my new ride for weeks now and thought I was nuts
Brandon
1988 Porsche 911 Coupe
http://www.tidalfish.com/bcw/porsche/pc.jpg
If you like fishing, click below, you will love the site! Great boards like here!
http://www.TidalFish.com
Old 07-20-2002, 11:24 AM
