does the WUR have a relay ?
if so where ?
is there a wiring diagram anywhere to be found ? |
According to the (more or less) useful Haynes.. the WUR (N9) has a relay (J15).. on what it looks like connections 30, 87, 85 and 86...
a Red/White cable goes out from the WUR into the 14 Pin connector.. a red/white cable from the connector goes into pin 87 to the relay Sorry but I don't have a scanner or electronic copies of the diagrams... Hope this helps a little bit |
One more thing... if you look at the second picture on this thread --> http://forums.pelicanparts.com/porsche-911-technical-forum/74392-what-these-two-parts.html
I think that the black relay (under the circled 1) is the WUR relay.. not very sure.. |
Thanks for that.
Infact one of these relay is suspect because the plastic cap keeps comming off I think its broken. Is this an allpurpose relay or does it have a part number ? |
| All times are GMT -8. The time now is 03:06 AM. |
