-   -   Minimize head & cylinder damage from broken stud(s) by retarding timing? (http://forums.pelicanparts.com/porsche-911-technical-forum/747786-minimize-head-cylinder-damage-broken-stud-s-retarding-timing.html)
NEWFIE 69 911E 05-02-2013 03:30 PM
Hi all,
Please see below quote from an old post:
Originally Posted by Doug Zielke (Post 491104)
I'm one of the ones that will drive my SC with the 1 broken head stud....carefully, at least, until the fall when it's top-end rebuild time. (Can't miss the SCWDP Round-Up, and few other events this summer!)
Last Saturday, I had breakfast with John Walker and he warned me about the possible consequences (head damage). I would not doubt this knowing his vast experience.
But here's a tip for those who are planning to tempt fate for just a few more summer miles.....
I found that if I *retarded* the ignition timing a few degrees, I could drive the car as hard as normal. This, *without* inducing the dreadful "pinging" noise of the head slapping the cylinder.
My mechanic suggested what I was doing in reality, was taking a bit of combustion pressure off the cylinders. It works, and although the retarded timing takes some snap out of the SC's acceleration, I can easily live with that for a little while.
Very interesting
Does anyone else have experience with this? Thoughts from the Pelicans?
Thanks, and safe motoring :)
Ronnie's.930 05-02-2013 03:49 PM
That is just another example of doing something stupid and trying to talk yourself into believing that it is ok . . .
Bob Kontak 05-02-2013 05:54 PM
Scratch the "hard as normal". Just drive it like a wimp and save up for the re-fresh this fall. A couple of degrees retard can only lessen the severity of potential damage.
What is the ROW 1980 CR?
Josh D 05-02-2013 07:37 PM
8.6:1
NEWFIE 69 911E 05-03-2013 10:58 AM
Thanks for the replies - any other thoughts?
Josh D 05-03-2013 01:17 PM
There is some logic to the idea that retarding timing will reduce cylinder pressure. Whether or not it is enough to prevent further damage due to broken headstuds is doubtful at WOT. It would just make more sense to keep the car properly tuned and manage engine stress with your right foot. I know, not easy to do. Just keep an itemized cost of a rebuild where you can see it while driving and that might help!
nicfranc 05-03-2013 01:29 PM
So can you drive on a broken stud ?
Has anyone driven on a broken stud for any length of time ?
How about more than one broken stud ?
Obviously not a good idea but if you could make it through the driving season
you could then schedule a winter rebuild.
manbridge 74 05-03-2013 01:29 PM
Ultimately, here is there deal on vehicles approaching 30+ years old... try not to "limp" them around with band-aid fixes and wishful thinking. This is why you see so many "my 911 burned to the ground, I rear ended a guardrail type threads."
And believe me when I say I've fallen into this trap before with cars that are as fun to drive as the 911. The temptation to drive them in sub-optimal condition is very strong.
Josh D 05-03-2013 01:35 PM
Ok, name one!;)
manbridge 74 05-03-2013 03:13 PM
... should have said cars that are almost and close as, fun to drive as the iconic 911.
Nearest guess would be ....... a modern sports car. That is how far ahead my 74 feels minus 915 trans.
Tippy 05-03-2013 03:58 PM
Retarding timing induces additional heat to the combustion process if too much.
Steve@Rennsport 05-03-2013 03:59 PM
I've seen the results of driving around with broken head studs for awhile and its not pretty.
In a nutshell, the heads and cylinder sealing surfaces beat each other up pretty badly and this means more machine work to repair. In some situations, everything is damaged beyond a reasonable repair since one needs to take too much metal off to restore the sealing surfaces and the result is excess compression and deck height problems.
My recommendations is always to stop driving it until the engine can be properly repaired as that's the least expensive solution in the long run.
NEWFIE 69 911E 05-04-2013 07:02 AM
Originally Posted by doverjxp (Post 7422128)
Just drive it like a wimp and save up for the re-fresh this fall.http://www.sioauxzc.info/5b.jpg
Thanks for the replies,
My 1980 911SC has approximately 190K KILOMETERS (RoW model, purchased in Germany). Soon after I purchased it in Rhode Island and drove the car home to Newfoundland, I discovered one broken head stud. Going against "better judgement", I have driven, and thoroughly enjoyed, the car for the past 5 summers, driving approx 7K KM in total. I have been checking for oil leaks, and the tell-tale ping, ping on a constant basis, but the car continued to run perfectly.
Late last summer the engine starting to ping-ping under almost WOT, but only when hot. So, I stopped driving it, and planned to complete a top-end rebuild over the winter as a project with my eager and talented 17 year old son. Alas, life got in the way, and we did not get time to work on the car over the winter, and spring is (sort-of) here!!
I understand the damage that we will cause by continuing to drive the car, and am prepared to fly-cut the heads, so I am considering driving it, carefully, like a wimp ;) for maybe 1K km over the summer, and start the rebuild with my son in the fall.
I am also prepared for, and appreciate, replies from those who think I am crazy, but that is how I am leaning.
So, call me crazy, I want to minimize the damage, and saw the old thread re retard timing to minimize damage, and would appreciate any additional thoughts on this. Thanks,
mreid 05-04-2013 07:45 AM
Almost every sc owner has driven with broken head studs. The difference is that once you see or hear symptoms you need to address them before minor wear becomes significant damage. I would fix the problem now. Replace the studs and rings while you're in there reseal the engine and you will drive for years with confidence.
mpetry 05-04-2013 03:52 PM
I once heard a similar argument about a rusty front pan (it's not that bad, no need to replace it, the forces aren't that great, etc etc). Guy came over to my house with his kid in the car and I took one look - I could see my shoe under the car when looking into the front compartment. It was held together by a spiderweb of rust and the grace of god. I shrudder to think what might have happened if it came loose (loss of control, head on into oncoming traffic) The guy sold the car instead of doing the fix.
Don't rationalize stuff like this - fix it! It will always cost more if you just "keep driving it".
/markp
don gilbert 05-04-2013 04:40 PM
http://forums.pelicanparts.com/uploa...1367714367.jpg
this is what will happen. just more mach. work and more dollars.
NEWFIE 69 911E 05-05-2013 05:37 AM
Thank - good advice all - maybe I should transplant the well-running 2.0L from my somewhat rusty 69 911E into the 80 911SC whilst I rebuild the 3.0L from my SC?
At least that way I will have a 911 to drive this summer!!
manbridge 74 05-05-2013 08:31 AM
^^ Why not? The guys who raced their 911s in the 70s-80s could supposedly change out an engine/trans in 2hrs at the track.
I'd say if you don't hear the "playing card in the bicycle spokes noise" you could probably enjoy some light driving.
NEWFIE 69 911E 05-05-2013 09:26 AM
Thanks - I only hear the "ping-ping" playing-card-to-spoke noise on WOT when the engine is hot. According to the old message (that started this thread), the noise (and damage ?) can be minimized by retarding the timing a few degrees ;) . Seems like a good idea to reduce damage for those of us who start to hear the noise but can't stop to rebuild, like when on a road-trip :cool:
This strategy assumes, of course, that no-noise = no damage . Comments?
Ronnie's.930 05-05-2013 11:04 AM
No offence meant, but this is not the case - nine times out of ten, when the engine is operated with a broken stud, you are going to find some damage to the cylinder/head mating surface regardless of what sounds you hear or what changes you make to the timing. Anyone that says differently, such as some that are advising that it is ok to drive, even moderately, with a known broken stud, are just plain wrong and allowing their "wishful thinking" to get the better of them.
NEWFIE 69 911E 05-05-2013 12:17 PM
Hi Ronnie's 930.
Thanks - no offence taken :) If that if the case, then damage is already done since I have been driving the car with a broken stud for some time now, so... a little more driving this summer won't make all that much difference ;)
I know that some fly-cutting will be required during the re-build, and I'm OK with that.
NEWFIE 69 911E 05-06-2013 04:26 PM
Originally Posted by NEWFIE 69 911E (Post 7424318)
Hi Ronnie's 930.
Hi again,
Assuming fly-cutting will be required, how much cutting is typical? How much should I budget for this service? Thanks,
mytoy 05-06-2013 07:06 PM
newfie
I can see that no matter what advise you are presented with you want reassurance that if you reduce the timing you can drive the car without any further damage.
As stated earlier any mileage put on the car in this state will induce further damage with or with out reduced timing. It is not only detonation which will cause problems but also blow by the reduced seal between the head and cylinder. It does not matter how much timing you take out you will still have combustion blow by at the reduced sealing area.
As you stated already you have run this way for 7k and I can not say how much damage is already done. It may be minimal and would only require a slight fly cut of the sealing surfaces. But if you had a lot of combustion blow by and eroded the sealing surface to a major extent then you can realize what Steve has stated, the replacement of a head and cylinder.
You have stated that you have a 2.0l at your disposal and could plop that in for this season. This would allow you to drive the car for this season while you and your son tackle the top end rebuild. Or you can continue on your present set mindset and drive the car for this season and take what ever consequences it may deliver. But do not cry if you have to replace the cylinder and head on your rebuild. Then again it may have minimal damage that would require minimal machining to correct but that is a risk you will have to wage.
Good luck on which ever way you decide.
NEWFIE 69 911E 05-07-2013 04:40 PM
Originally Posted by mytoy (Post 7426990)
newfie
Hi Gary, many thanks for the comments and suggestions.
Yes, I have a running 2.0l from my 69E (but with Webers) that I could swap over into the SC. I have never really investigated the details of this transplant, but I know it is doable. I'm guessing the wiring and fuel pump conversion would be the biggest issues :confused: Maybe I'll start (or search for) a thread on 2.0l transplant into SC!
It really is the best option!
