84 3.2 howl/rumble noise
In the last few months my 84 3.2 has developed a low howl or rumble noise. More pronounced when under way, can hear it at idle with the lid up. Sounds like it may be from the pulley area. I removed the sound pad a while back due to deterioration.
Car has 63k. Think I should remove belt and check for pulley wobble? Outside of turning up the radio any ideas. Bob 84 Cab |
Wheel bearing or CV joint.
Is this thread in the right place? |
moved to tech
Go-Kart Mozart
If you can hear the noise at idle that rules out wheel bearings and CVs. Could be the alternator bearing going bad. Do you have A/C installed? Could be the compressor clutch. You could remove the Alt/fan belt and briefly start the engine to rule out or pinpoint the alternator bearing. -J
86FlatSix
I have the same symptoms pretty evident howling when I use it on long drives or engine is on its normal working temperature for a long period of time and hear it when idling. It only occurs on long drives say 50 mile run or so. The howling is partnered with a slight vibration on the alternator fan so I suspect it has something to do with its bearing.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
muck-raker
alternator bearing. Maybe readjusting the belt (slightly looser) will make it go away.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Time to replace the belts anyway. Will give it a try and see if it effects the noise.
Bob |
