-   -   Which fan/alt should I use, and a quick wiring? (http://forums.pelicanparts.com/porsche-911-technical-forum/747915-fan-alt-should-i-use-quick-wiring.html)
Mark Henry 05-03-2013 09:09 AM
I have two of everything, one is I believe a '69 and the other a '75.
The one fan is for sure Bosch, shallow depth, so 55amp right?
The other has no manufactures label and is the deep depth. Do you know what brand it is?
I have 2 fan pulley haves one small and one bigger, whiich one should I use?
Also I won't be using the accessory pulley part of it, so can I cut that bit off? or should I leave it alone?
Wiring it has two terminals of almost eveything (the bosch unit only has two B+'s) do I just jumper these together?
And finally do I just use the bosch external regulator on both these units?
Going on a 914 3.0 conversion, hoping to sell the one I don't use once I know the other works well....or should I just keep it for a spare?
thanks
http://forums.pelicanparts.com/uploa...1367597188.jpg
http://forums.pelicanparts.com/uploa...1367597215.jpg
http://forums.pelicanparts.com/uploa...1367597240.jpg
http://forums.pelicanparts.com/uploa...1367597264.jpg
