1988 Carrera door not opening from inside
My driver's side door will not open from the inside. Last year, I added dynamat to the doors to try to seal it up acoustically and I thought maybe it was gumming up the mechanism. But, I opened it up, cut away all the dynamat and I still have the problem.
With the door panel off, I can pull the lever and the door will open but when I reassemble the panel, there isn't enough pull to disengage the door latch. I tried turning the pin to shorten it but ran out of room.
I'm thinking the cable is stretched. Is there any mechanism inside the door to tighten the cable?
Old 05-03-2013, 08:13 PM
