bent door release rod
Looks like I bent my innser door release rod -- the rod that the inside latch attaches too.
any tips on bending it back? Also, is it supposed to be completely straight?
assume some map gas and a vice?
1983 911SC Varioram
O #19
Old 05-04-2013, 02:47 PM
Recreational Mechanic
Nickshu's Avatar
Which rod do you mean? Between the pivot and the handle or the Bowden cable between the pivot and the actual latch?
Sent from my SPH-L710 using Tapatalk 2
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 05-04-2013, 03:54 PM
the small rod that connects to the inside door latch
1983 911SC Varioram
O #19
Old 05-04-2013, 04:52 PM
Nickshu's Avatar
Those are pretty weak. I broke one trying to bend it cold. Heat would be a good idea.
I just replaced this entire mechanism. Porsche no longer makes the original version... Superceded to a later version that requires a new style that is a bit longer. My point is that if you break it you'll need to replace this rod, the pivot, and the Bowden cable with the newer style... Assuming you want new parts vs used.
For me I replaced both sides with the new updated parts. My original 82 bowden cables were super stiff and the cable housing was rusted. Interesting the original SC Bowden cable wasn't a cable at all... It's a stiff thin metal wire in a cable housing. The updated version is much better as it's an actual cable which is much more flexible. I think the superceded part date was 86 or 87 but not sure.
Old 05-04-2013, 05:15 PM
thanks. I think heat will work. it was an unforseen consequence from trying to adjust my window.
1983 911SC Varioram
O #19
Old 05-04-2013, 05:51 PM
used a vice and did it without heat. worked well.
sigh of relief and a beer.
thx,
1983 911SC Varioram
O #19
Old 05-05-2013, 10:15 AM
