will Carrera 3.2 front brakes fit onto a 72 911T?
Hi guys,
I bought a set of front calipers from an 87 911 for my 912E. However, I can't use them because they would kick me out of the Street Prepared class I want to autocross in. But, my roommate has a 72 911T. Would they fit his car? I have a set of essentially brand new rotors too. If they will fit, we're going to keep them for his car. If not, I guess I'm just going to resell them. Thanks, David
Remember our friends: Warren, Ron, Grady, and Steve. 76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster |
Measure the distance between the mounting holes for the calipers. Early cars are 3" apart, Carerra's are 3.5". Unless the struts have been replaced/upgraded the Carrera calipers will not fit.
The other issue is the thickness of the rotor. The T uses a ~20mm wide rotor and the Carreras are ~24MM. SC brakes are in between, they have the thinner rotor but the wider bolt spacing. Todd |
