SaltWaterDog's Avatar
Porsche Crest Seat Belt Warning Light - Where to get one?
Hello
Does anyone have a spare seat belt warning light?, or even an old junky one?
Part number 944-632-213-00-OEM - discontinued
Our 1988 911 Carrera (73k) is perfect (pic below) and original however the seat belt warming light just exploded one day and somehow I lost one half of the red lens (bottom half) which use to read " Seat Belt" or something like that. I have the top half, need the bottom half to finish the puzzle. Otherwise having the random 3 lights on the dash with no cover is sort of annoying.
Thanks for any leads or ideas on how to fix it.
Joe
Old 05-07-2013, 08:37 AM
schumicat's Avatar
i got it on ebay cheap. 944 used one that fits with different pictograms/wording.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-07-2013, 10:07 AM
sky1jord's Avatar
Amazing - Precisely the same thing happened to me just today - Seemingly out of nowhere the red lens "exploded" with the bottom half disappearing and the top half intact. Must be the ol' warning lamp lens bomber at it again!
Old 05-22-2013, 02:10 PM
Bland
RWebb's Avatar
put the remote for your V-1 there
Long Term Maintenance:
http://forums.pelicanparts.com/porsche-911-technical-forum/189572-long-term-commonly-neglected-maintenance.html
Old 05-22-2013, 02:27 PM
Rescuer of old cars
Arne2's Avatar
I might have a spare from my '84, if it's the same one. Lens is intact, not sure about the bulbs and such. I'll try to look for it tonight.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-22-2013, 03:46 PM
Blackbyrd's Avatar
I have two of these
Old 05-22-2013, 09:40 PM
cdrik915's Avatar
Golf MK1 parts.
You'll find the same .
LIGHTER = FASTER !!!
Old 05-22-2013, 10:22 PM
Rescuer of old cars
Arne2's Avatar
I do have a spare, but that has shown me that there are at least two versions, as my spare is different than the one in the car. The spare has the word "BRAKE" spelled out, while the one in the car has only pictograms.
1972 911T coupe
Old 05-27-2013, 01:45 PM
Pavement Pounder
X JBM X's Avatar
FWIW, I think my '84 says Brake...
Old 05-27-2013, 02:06 PM
Rescuer of old cars
Arne2's Avatar
I wouldn't be surprised. I suspect the one in my car now is the later replacement, and the original is the spare. The spare one has obviously been used.
1972 911T coupe
Old 05-27-2013, 02:43 PM
Arne, is one of your lenses for sale? The one from my 87 is half missing!
1987 Targa Indian Red
2001 Volks Jetta (winter beater)
Old 05-28-2013, 06:04 AM
B15 AAL's Avatar
Hi all,I know this is an old thread but I was wondering how to remove this part from the dash. It no longer works and would like to install a voltmeter of some description.
Old 03-18-2014, 10:33 AM
Bland
RWebb's Avatar
not as easy as it should be - pull a couple of gauges and do the reach around to push on it
when it does not come out, keep pushing on one side or the other, top or bottom
you will eventually see a small black tab on it - push that down with a small screwdriver and keep pushing while mashing down every tab you see emerge
it will come out in a couple of days of this
if your car is fairly new it will be easy
note that the dash has 2 layers of sheet metal so cutting is not as easy as it might appear
Old 03-18-2014, 11:14 AM
B15 AAL's Avatar
Thanks RWebb, thought as much.
Not intending on cutting anything on the car. Probably cut up some off the shelf item to fit the original hole,
Something like this but maybe a bit more subtle,
12v LED battery status monitor level meter indicator A | eBay
Old 03-18-2014, 12:08 PM
group911@aol.co's Avatar
You can also pop the lens off the front and see the little tabs Rwebb is referring to. Might be able to get a tiny screwdriver in from the front to release them.
You can also replace the bulbs if you want to make it work.
Thanks,
Bob
group911@aol.com
Old 03-18-2014, 04:23 PM
crdik915, you wouldn't happen to know the corresponding VW part number, would you?
-Glenn
Old 04-01-2014, 11:02 AM
Also, if anyone has any of the 3-segment lenses, I could really use one! I would be happy with either one of Arne's pictures above. I have the "wrong" one right now, that I could trade - it has the seat belt light on top, and two brake lights on the bottom.
Old 04-04-2014, 07:35 AM
djk_wff's Avatar
Bottom seatbelt transparent window
Hello all, this sure does seem like a common issue!
I need the bottom cover, or window, or " the thing that illuminates when the seatbelt is not secured".
Does VW have an adaptable part? Part number?
Any other options?
944? p/n?
thanks...
Old 08-05-2014, 06:30 AM
TheSt|G's Avatar
If anyone has one laying around, I could use it as well. My current one functions fine but the front plate lens is just gone.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 08-05-2014, 06:33 AM
Blackbyrd's Avatar
I have two of these right now
complete assembly in excellent condition
Update just got these 8/11/2014
Old 08-05-2014, 11:50 AM
