Doug E's Avatar
Alternator Belt Shimming Question
I put 2 new belts on the 911 today but after doing so I have a shimming question for the experts relative to the alternator belt...
to get the proper tension (about 1/2" deflection at the mid point of the belt) I used 2 shims between the pulleys and 4 on the outside between the washer and the nut.
Other information: in addition to using 6 shims in total, I used the 10x710 belt and torqued to 40 NM per Wayne's book.
Seems strange to me to only use 2 shims on the inside of the pulleys and have 4 on the outside but when I tried 3 and 3 the belt felt too loose (almost 1" of deflection).
Does this seem right to you or did I do something wrong? My other thought is that maybe I will need to readjust the belt (ie., add another shim inbetween) after a few thousand miles when the belt stretches.
Comments and/or thoughts?
TIA
Doug
'81 SC Coupe
Old 07-17-2002, 06:44 PM
Early_S_Man's Avatar
Porsche Crest
Doug,
Sounds fine! I have encounter several belts that only needed 1 or 2 shims between the pulley halves.
Only thing is ... you should recheck the belt tightness in a week or two, 500 miles, maximum! Then, after the belt is broken in ... it will have stretched a little, so you will need to take out a shim or two, and move it/them to the outside with the others!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-17-2002, 06:55 PM
PORSHIN's Avatar
Send a message via AIM to PORSHIN
Hey Doug!
Good to hear from you. I was going to respond but Early already hit the nail on the head. It's not unusual. Like he said you may even need to take one out after a few miles.
Rob
Old 07-17-2002, 07:00 PM
Doug E's Avatar
Thanks for the quick response guys. I will definately recheck the deflection in about 250 to 300 miles.
Doug
'81 SC Coupe
Old 07-17-2002, 07:15 PM
My wrench informed me that authorized Porsche belts are actually 9.5 rather then aftermarket 10". This would explain these belts needing only 1 or 2 shims between the pulley because of the increased length. Also remember to keep turning the fan blade when tightening to prevent impinging the belt when torqueing.
Old 07-17-2002, 08:31 PM
cary's Avatar
I think the 9.5 is the width. 9.5 cm by 710 cc. But all you can find is 10 cc. A little wide. Tried to order straight from Continental. I can't get mine to stop from whining at launch.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 07-17-2002, 09:00 PM
