-   -   wiring question 70 t/ front lid seal (http://forums.pelicanparts.com/porsche-911-technical-forum/748857-wiring-question-70-t-front-lid-seal.html)
wolfyboy 05-08-2013 07:34 AM
I am closing in on my final reconnection issues on a 70t. Below are some pictures that I need some help with.
1. Behind the dash at the rear winshield heater switch there is an open male connector and behind the blower i found 2 wires connected that show on the SL35 wiring diagram a note that says Nebelschlusslicht (SW). White w/ black and white w/ green. Do these connect on to the heater switch?
2. Which location does the front hood seal belong. ? Top or bottom photo.http://forums.pelicanparts.com/uploa...1368023553.jpg
http://forums.pelicanparts.com/uploa...1368023571.jpg
http://forums.pelicanparts.com/uploa...1368023584.jpg
E Sully 05-08-2013 09:49 AM
White/Green should be optional rear foglight.
White/Black is probably for 2 stage rear window defroster. Single stage only used the Black wire.
Trunk seal is upper, lower is front bumper to body seal.
wolfyboy 05-08-2013 08:17 PM
I was mistaken the open connector is on the cigarette lighter. Do these wires need to be connected?
E Sully 05-09-2013 12:26 PM
I want to avoid confusion here. Do you have the optional webasto gas heater, and do you have a single or 2 stage rear window defroster? Any other options like front or rear fog lights or rear windshield wiper?
wolfyboy 05-11-2013 07:44 AM
My rear window has red with white wire and brown ground. I have not used so I do not know if single or two stage. How do you know? Also no fog lights or special heater.
E Sully 05-11-2013 09:09 AM
It sounds like you have a single stage. The defroster switch will only have one position. The W/Bk will be spare. With 2 stage there would be R/W R/Bk and Br going to the rear window.
In this picture of the rear electrical console, you will only have the black relay #2 if it is single stage. If you have item #6 the rectangular relay then it is 2 stage.
I am going to check a few things to check the W/Gr wire.
http://forums.pelicanparts.com/uploa...1368288336.jpg
E Sully 05-11-2013 12:37 PM
As near as I can tell without being able to physically check myself, the W/Bk should be a spare for 2 stage defroster. The W/Gr should be a spare for the optional rear fog light. You can verify it by checking continuity to the spare wires bundled by the drivers rear tail light, shown in the picture.
http://forums.pelicanparts.com/uploa...1368301027.jpg
