ventilator motor help, '82 911SC
My front fresh-air ventilator motor seems dead. Sliding the top dash lever to the right over the I, II, III positions puts a ground short to motor socket (on harness) pins 2,3,4 as expected. Also there is 12volts on pin 1 as expected. If I put 12v (from charger) across motor PLUG pins themselves, the motor never spins. So dead motor! How do I get the housing apart? Help please!
Old 05-08-2013, 11:59 AM
pete3799's Avatar
Disconnect two hoses, the slide cable, unplug, and remove two bolts one on either side of the motor housing, remove housing. Pry off the four round clips to separate the halves.
Disregard the arrows ( only picture i could find)
Pete
79 911SC RoW
Old 05-08-2013, 12:23 PM
Thanks, Pete,
I assume once I get the two halves apart I can extract the motor itself and see if it is repairable?
Algernon
Old 05-08-2013, 04:12 PM
83 911 Production Cab #10
JJ 911SC's Avatar
PM me an email address and I'll send you a step by steps with lots of photo.
Who Will Live... Will See
Old 05-08-2013, 05:16 PM
Thanks JJ, PM sent.
Algernon
Old 05-08-2013, 07:27 PM
schumicat's Avatar
if you do some searches you can find an old write up of using a generic motor old by NAPA to replace it. it requires some minor modification.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-08-2013, 07:40 PM
