how to remove weber manifold studs
Trying to remove the manifold studs without ruining the manifolds. Do they unscrew or press out? Do you have to drill them?
Thanks for the help. Dean |
best way is with a collet stud puller (our host sells them) BUT you do have to pull the manifold off, pretty easy job, 6 nuts.
| All times are GMT -8. The time now is 12:58 PM. |
