Swepco 210 ! good?
A couple days before my last track day, I drained my trans and filled it with Swepco 210 (two-ten). I was running Valvoline 85/140, as my transmission seems to like the heavier fluid. For reference, I normally change the trans fluid after every track day.
In short, with the 210, it shifted like crap. It was hard to get into first, and hard to get it *out* of gears.
Last night I drained it and filled it with the Valvoline stuff again, and shifting returned to what it was before.
Is Swepco 210 totally wrong for a 915 or what?
Old 07-17-2002, 10:04 PM
JWest's Avatar
I was hoping someone would compare 210 to 201 to something else. Have you tried SWEPCO 201 in your trans?
Old 07-18-2002, 05:54 AM
Early_S_Man's Avatar
Porsche Crest
Actually, I prefer the Swepco 212 with moly that Pelican now carries ... over the thinner blue 201 or red 210. I used the gold-colored straight SAE 90 201 back in the Garretson days ... with great results!
Was the Valvoline a conventional variety, synthetic blend, or full synthetic SynPower?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-18-2002, 06:44 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Ill be putting in some 201 tonight...hopefully. If i can find the turkey baster.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 07-18-2002, 07:44 AM
I have tried 201, which I put in just after I got the car. Shifting improved a little, but the Reagan-era fluid that was in there probably didn't help, nor did the little dog teeth that came out with said fluid.
When I had it rebuilt, they filled it with 201.
When I started autocrossing the car, I changed the fluid, and put in normal OTC fluid because that's what I had available. Shifting didn't change.
Just before my first track day, I put in 201. No change.
On the next fill, I used organic 85/140 - shifting improved over the swepco 201.
I tried Mobil 1 synthetic gear oil last winter for a month or so of street driving and a track day. The transmission didn't have the same 'feel' as with organic fluid - it was noisier, and it seemed like I could 'feel' the shifts more, like I could actually feel the parts moving when I shifted.
So, now I'm back to organic 85/140. I might try the 212 next. At $40/gallon, these can be expensive experiments!
Old 07-18-2002, 09:10 AM
Efrain68912's Avatar
Give 203 a shot. From what I hear, the difference between the 201 and 203 is that the 203 will offer better protection against overheating.
Efrain
68 912 Coupe
62 A-H Sprite (VARA DP)
97 Van Diemen FC
94 Mazda RX-7
Old 07-18-2002, 10:57 AM
