-   -   What about the oil in the front cooler and the lines that go to and return from it? (http://forums.pelicanparts.com/porsche-911-technical-forum/749053-what-about-oil-front-cooler-lines-go-return.html)
Kissov356 (guest) 05-09-2013 12:11 PM
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Changing Engine Oil - 911 (1965-89) - 930 Turbo (1975-89)
Nick at Pelican Parts 05-09-2013 12:11 PM
You do not have to drain the oil cooler or lines. Just drain your engine oil, refill with the correct amount. Idle engine until warm. Then check oil level and top up if needed.
- Nick
gamin 05-09-2013 02:45 PM
Nick is correct. But if you absolutely feel that you must get that oil out, you can spring for elephant racing finned oil lines that have a provision for their drainage.
