Moaning "tugboat" sound, wheel bearings?
Howdy,
I've got this moaning tugboat type sound that i was thought was a sticking caliper. I've since replaced all 4 calipers and flushed the braking system and the problem persists. It doesn't happen every time, but often when stopped and letting the clutch out partway to roll forward the sounds begin. It goes away if i partially depress the brakes (but not necessarily enough to stop the car) or if i speed up or stop. I'm thinking it might be the wheel bearings. Do you agree and is if so is there a proper wheel bearing failure test?
1986 3.2 Meteor Metallic Grey |
A failing wheel bearing makes a moaning sound that increases with speed this doesn't sound like your problem. I cant think of an explanation for your problem.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Less brakes, more gas!
CV joint
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Sure does sound brake (system) related,......mmmm.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Go-Kart Mozart
+1 I've had several cars where I could induce the moaning sound at any time by letting up on brake pedal pressure just the right amount. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
76 911S Targa
Wheel bearing noise changes as you swing the car left and right while driving at normal speed. The noise will be louder turning either left or right. Often the noise of a wheel bearing begins as a low growling noise which eventually degrades, over many miles to a shrill screech. Your description does not match this sound.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
a wheel bearing will not go away. it will be a growling sound as mentioned or imagine rough, dry bearings trying to turn.
not sure what a tugboat would sound like. CV joint, something in the clutch itself, parking brake.
I have had the same thing on my car for 10 years now. A buddy of mine insists that it happens when the rotor begins to warp ever so slightly, and the pads rub on the high spot.
As perfectly stated by others, a bad bearing will change its sound when you swing the car right and left. I plan to replace my front rotors and rebuild the calipers in a few weeks. If the moaning stops, I will let you know.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Tugboat noise is the best description I could come up with.
1986 3.2 Meteor Metallic Grey Last edited by tmblackflag; 05-10-2013 at 09:29 PM.. |
1986 3.2 Meteor Metallic Grey Last edited by tmblackflag; 05-10-2013 at 09:28 PM.. |
