Part number needed please!
I am working on a total re-seal of the oil leaks on my 85 Carrera. I have a different thread about that.
One of the many (endless) "while I am in there" projects is the intake. Since the intake is off now is the time! I want to replace all the rubber bits that cause vacuum leaks. http://forums.pelicanparts.com/uploa...1368215106.jpg This rubber "Y" is what I need. This one is likely the one that the car came with. 146,000 miles and 28 years ago. http://forums.pelicanparts.com/uploa...1368215180.jpg It connects the pressure regulator via a little hard plastic hose to a rubber elbow on each bank. The Pelican catalog has this part superseded with part number 928-573-727-02 but that is a hard plastic part. Any ideas on where to get the correct part? What part number do I need? |
This is the part for a 993 intake system that uses the same size as your vacuum lines.
928 573 727 05 |
Vacuum tee
| All times are GMT -8. The time now is 12:12 PM. |
