1984 911 Carrera Targa
Siezed automatic radio antenna.
Just looking for advice.
1984 Carrera Targa.
The automatic radio antenna is siezed. Not a big deal, but it would be nifty if it worked. It looks like a royal pain to get to and fix. Anybody out there tackled this?
Old 05-09-2013, 03:59 PM
rgrimm's Avatar
the antenna on my '84 was seized when I bought the car. I put in a cheap manual, then about a year later installed an electric replacement I bought off EBay. Just looked...Woody's Custom Shop has one for $80 that looks like what I bought (it was a good six years ago). Not hard to install. When I took the original electric apart to look at it, it was obvious I'd never get it working...massive corrosion.
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 05-10-2013, 12:25 PM
Thanks, that's what I expect to see when I dive into it. Now the question is, should I buy the new one ahead of time or should I wait until after I see how bad it is.
Old 05-10-2013, 02:04 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Mine was full of aluminum mushrooms! If you want another auto model, eBay and search Blaupunkt auto antenna.
http://www.ebay.com/itm/Blaupunkt-Power-Antenna-Autojet2-Chrome-7691240732-/271160030924?pt=Car_Audio_Video&hash=item3f2265b6cc&vxp=mtr
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-10-2013, 02:05 PM
sudo apt-get purge 930
equality72521's Avatar
I rebuilt mine, pretty easy. You will need several screw drivers to hold the tabs while you work around the housing. Once apart you will see how dry the gears have become so a little cleaning and new grease there. Also, the telescopic metal antennae will have many years of grime. You will need to spray it down with a penetrating lube. Then, properly hook the wires to the battery to extend it while pulling the end until you get it fully extended. (I can't remember which way the wires go). Spray it down again and retract the antennae. Repeat this several times cleaning it each time you extend. Eventually you will get all of the black goop out and it will work fine then.
--clutch-monkey
Old 05-10-2013, 02:47 PM
