Damage To Whale Tail--Thoughts On Repair
First off-I did it so the children and the wife are still alive. Has anyone experienced a spot repair on the fiberglass grill? I would like to know what kind of epoxy may repair the crack and any thoughts on the correct black paint code.
TG
1986 930
Littleton, Co
Old 05-13-2013, 07:00 AM
That's an easy one,, just remove the tail take off the rubber
And repair it with some glass and a dab of filler if you have
Any pin holes, the black is black. I have VHt semi gloss and
It looks great . You'll be done by the weekend
Old 05-13-2013, 12:14 PM
theiceman's Avatar
ok .. what did you drop on it
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-13-2013, 12:47 PM
A full size cooler as I was bringing it down from the attic. Daughter took off running in anticipation of a lot of foul language as I have spent 13 years reminding them about bicycles and other garage weapons. I suspect she thought this was pretty funny stuff.
TG
Old 05-13-2013, 02:19 PM
That gave me a good laugh! Your family sounds hilarious. Reminds me of mine, and my youth too!
1987 911 Guards Red Carrera (current project)
1988 BMW 325 iS (sold)
1989 325iX (winter blaster)
2013 VW Jetta TDI (civilized touring car)
1991 Saab SPG (sold)
Old 05-13-2013, 03:53 PM
Hydrocket's Avatar
TG
I suspect she ran away so she could laugh at you without getting in trouble!!
Nothing worse than reminding the family to be VERY careful about the 911, then bunging it up yourself...LOL
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 05-13-2013, 03:57 PM
I agree with this approach. Simple fix
Old 05-13-2013, 05:43 PM
Cooper911SC's Avatar
I would suggest using JB Weld and woven fiberglass.
The JB will bond well and handle the heat cycling very well.
I have repaired my own Carrera wing as well as client wings with this method.
The JB is also easier to work with as it is firmer than fiberglass resin so it will stay where you put it rather than sagging or running.
Sand or grind the crack with 80 grit to create a V shaped void.
Trim the patch piece of fiberglass and mix up some JB.
Apply the patch.
Sand smooth with 320 dry and 600 wet.
Mask all of the black area with 1/8" tape to get the curves right at the corners.
Lightly Scotchbrite the rest of the louvres with either Green or Gray pad, wipe with prep solvent and spray with Wurth Satin Black or another favorite like Rustoleum etc.
You will be good to go after a nice weekend project in the garage.
(of course you should remove decklid and wing. I typically disassemble the AC condenser and remove the screens. Mask the inside of the louvres off).
You can also take the time to Scotchbrite and repaint the screens under the louvres for a fresh look.
Cooper
Old 05-13-2013, 10:28 PM
Free minder
Aurel's Avatar
You could use a bumper repair kit from autozone. That is epoxy with black filler, I used it on my dashboard with good results.
Bondo/Epoxy bumper repair syringe kit (280) | | AutoZone.com
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 05-13-2013, 10:41 PM
Thanks for the ideas---good ones.
Is the top fiberglass section with the grill separate from the bottom and accessible by removing the rubber lip? I may try to remove it so I can repair and paint at a safe distance from the car----I have momentarily lost all of my confidence.
TG
1986 930
Littleton, Co
Old 05-14-2013, 01:40 PM
