Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
The mystery of my missing engine.
Compelling title, eh? "Wait...is the ENGINE missing? Like...it's not there anymore?"
No, not exactly.
It appears as if 1, if not 2 of my cylinders is not firing. "A dead hole", as they say.
First things first: Motor is a Euro 3.0 Carrera case, with mostly early engine bolt ons. (smaller distributor, etc...)
It has, at some point since I've had it, run brilliantly.
Important info:
MSD ignition and Coil.
New Battery
New Beru Wires, New Bosch Spark Plugs, New Cap & New Rotor
Injectors tested: They are all equal, and spray pattern is perfect.
Weak spark in cylinders 2 and 3.
Plug wiring is correct
My next thought was perhaps to change out the distributor if I can find a spare somewhere.
I've been told by Steve Grosekemper (Deiter's) and Marc Kinneger (Black Forest Automotive) that it's at least one cylinder down under load.
Can anyone help solve this mystery?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-19-2013, 10:03 PM
pete3799's Avatar
I'd do a compression test to see if they're all healthy first.
Pete
79 911SC RoW
Old 05-20-2013, 05:38 AM
ivangene's Avatar
and a leakdown
Ed M
86' Coupe
Old 05-20-2013, 06:10 AM
ivangene's Avatar
how did you measure "weak spark in 2-3"
Ed M
86' Coupe
Old 05-20-2013, 06:11 AM
Rennch on YouTube
rennch's Avatar
pulled a wire, plugged a spare plug in, and cranked the motor
Michael O'Neal -
Old 05-20-2013, 06:31 AM
Rennch on YouTube
rennch's Avatar
Good idea...haven't done that yet.
I don't have a compression tester yet, so I'll have to grab one.
Michael O'Neal -
Old 05-20-2013, 06:32 AM
ivangene's Avatar
so it "looked" weak compared to others....
not a good measure - the only reason for that would be a wire, or a plug - but its not a good measurement
RE compression tester - I bet someone near you who has one would loan it to you for a couple beers
I would
Ed M
86' Coupe
Old 05-20-2013, 07:11 AM
T77911S's Avatar
you may be confusing weak spark with just a weak cylinder based on what the 2 guys told you.
is it an idle issue or are you down on power driving?
compression and leak down test are needed.
i saw your fuel test. you might consider going back and doing it again if the teat above looks good. next time, fill the bottles at least half way, the more the better. do it WOT.
not the dist.
you could start it cold and check the temps of the exhaust at the exhaust ports to see if you have one not firing.
you also need to check timing. are you getting full advance?
check mixture.
air leaks
how do the plugs look?
fuel pressure- system pressure. fuel volume
not knowing what the engine is really doing i have to throw out the basics to cover it all. again, based on "one cylinder down under load" tells me its a driving issue. is this a WOT problem?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-20-2013, 07:27 AM
Rennch on YouTube
rennch's Avatar
I got a compression test kit yesterday. Am hoping to find time to run it today. I've never done one before, so I'm hoping I'll do it right.
Michael O'Neal -
Old 05-21-2013, 11:21 AM
Rennch on YouTube
rennch's Avatar
Ok, update.
So, I was digging a bit further into the Pertronix situation, and I found this wire very frayed. It had been rubbing on the inner rotating cylinder of the distributor:
I cut it and patched the area. (I ordered a new Ignitor II yesterday, but I wanted to see if it would make a difference)
So...I went to start the car, and something very strange happened.
In the key "on" position, I got fuel pump, dash lights, etc.
When I turned it to fire the engine, everything abruptly cut out. I have nothing...no electrical whatsoever now.
I was able to reproduce it, but it's intermittent. and I can't start the car at all now.
Ugh.
Now what???
Michael O'Neal -
Old 05-22-2013, 12:41 PM
Dave Colangelo's Avatar
My guess as to your electrical issue is that when patching it you left something exposed and the coil grounded though that point into your electrical system, check your fuses. Also check your bat connections and make sure they are secure. How exactly did you patch up the bad section of wire?
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-22-2013, 12:46 PM
Rennch on YouTube
rennch's Avatar
Regards
Dave
I checked the fuses. It's intermittent...so tough to find.
to patch it, I cut it and put a male and female connector on it.
Michael O'Neal -
Old 05-22-2013, 12:50 PM
gtc gtc is offline
abides.
gtc's Avatar
Do you have a set of points you can swap in to check the pertronix?
Graham
1984 Carrera Targa
Old 05-22-2013, 02:33 PM
Rennch on YouTube
rennch's Avatar
I don't. I wish I did.
Michael O'Neal -
Old 05-22-2013, 02:37 PM
I have had a lot of success with electronic issues by just cleaning up the grounds and swapping all the fuses out. When doing so I clean up the fuse tabs until they are clean copper. There may be some rouge corrosion in there somewhere.
Regards
Dave
Old 05-22-2013, 04:16 PM
Rennch on YouTube
rennch's Avatar
This is a problem that didn't exist before today though. And I've been messing with my wiring in the engine compartment. I feel like I had to have unplugged something or some such.
Michael O'Neal -
Old 05-22-2013, 04:23 PM
