Recommended exhaust studs
I have SSI's to install on my 3.0l that I bought to put in my 71. Upon inspection, I have 5 or 6 short studs including one that is really short. The rest are longer as is proper for an 82 SC motor. What studs should I buy? Pelican has 3 or 4 different ones that are 8 x 50mm or 51mm that range in price from $2.25 - $4.00. Is there an aftermarket option that is better?
I'll also need exhaust gaskets, those are pricey at $7.50 each, any other options? Edit: I found some exhaust gaskets that came with the motor, they are marked '40' and measure 40mm ID. These are right for my 82 3.0l, correct?
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 05-14-2013, 06:56 PM
sudo apt-get purge 930
equality72521's Avatar
I bought stainless from Fastenal.
--clutch-monkey
Old 05-14-2013, 07:14 PM
Mark, is this the one you bought:
M8 x 50 A2 Stainless Steel DIN 939 Double End Stud | Fastenal
2010 Cayman
Old 05-14-2013, 07:20 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Worst idea ever, dissimilar corrosion issues......you can either have the studs and nuts corrode, or the aluminum head, pick one. That's the reason that fasteners are coated/plated with zinc and copper nuts are used....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-15-2013, 10:35 AM
Northern Motorhead
wildcat077's Avatar
I just went over to my local auto parts dealer and picked up some generic metric exaust studs ... they'll be good for another 20 years !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-15-2013, 01:14 PM
Spiderman
Jesse16's Avatar
Or you can make your own from a high quality threaded rod from McMaster Carr. Thats what I did 4 years ago and they still look great. Steel is steel in general. My car is not likely to get "rusty" so they aren't a big concern. Stainless tends to gall so not always great for fasteners.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 05-15-2013, 01:24 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Best combo I have found is stainless studs with brass nuts.
They never seem to gall or seize...dont rust...and are relatively cheap.
Bob
Bob Hutson
Old 05-15-2013, 04:50 PM
