CONCLUSIVE! "Legacy" non-barrier hoses do NOT leak.
Both the EPA and SAE are now on record stating that converting a Porsche 911 R-12 system to R-134a DOES NOT require switching to non-barrier A/C hoses. Once the original factory "non-barrier" hoses in our 911's have been "saturated" with the lubricating oils used with the R-12 refrigerant they will not leak R134a refrigerant.
That also means, obviously, that the factory use of non-barrier hoses is NOT the source of long term, ~2 years, refrigerant loss in our cars, R-12 or R-134a, That many of us have experienced, are experiencing. Then what is...?? System high side pressures that exceed the design specification for those OEM, factory installed, non-barrier hoses. Even Kuehl, along with both of the above entities, recommends the use of a binary pressure switch to prevent compressor "over-run", when converting to R-134a. The basis for this recommendation arises from the use of a "vent-to-atmosphere", pressure relief valve, used to alleviate inadvertent system over-pressuring, on many older systems. Since R-134a typically operates at higher system pressure vs R-12 these BOVs are likely to vent some of your refrigerant absent a method of prevent those pressure spikes absent some preventative measure(s). But will preventing the compressor from over-running and thus over-pressuring the system be a complete solution for our Porsche's. Maybe not. We may need a method for keeping/"starting" the front lip condensor fan whenever system high side pressure exceed a specific level....a TRINARY pressure switch with the extra element used to power the front lip blower regardless of ignition switch position. The mere existance, and current availability, of 450 PSI refrigerant pressure relief valves/fuses used with many "legacy" R-12 automotive A/C systems would indicate that even R-12 system overpressures in that range are possible. So to what surge/spike pressure level might we see when converting to R-134a if no preventative measures are taken? Last edited by wwest; 05-16-2013 at 10:03 AM.. |
Read everything I could find from the EPA and never found a mention of a Porsche 911...perhaps you could quote them for us.
Banned
I've never seen an adequate answer, and have often wondered why hard line couldn't be used in place of hose. The difficulty I foresee is that you essentially double the the number of fittings and connections. |
Since Chrysler is the only marque mentioned by name then do they only apply to them..? |
How early, how soon, in the automotive A/C market was the problem of system overpressures discovered/forecast and addressed? Certainly long prior to the "build" of my 92 Ford Aerostar. |
Wwest, why are you starting a thread based on 1 statement made by the EPA?
1 statement that seems to reverse their previous position which they have held securely for the past 20 years. 1 statement which they contradict their position on the same web page with the following: " Cracked or damaged hoses should always be replaced with barrier hoses." If the EPA feels or thinks non-barrier hoses are OK then why are they suggesting that if you need to replace them you need to use barrier hose? Does that make sense? Can you explain that for the forum? Why is the EPA flip flopping so much? Here are just a few factual (published) studies on this 20 year old subject. Let's start in the beginning, well before the consensus that refrigerants harm the environment: SAE Technical Paper 710039, 1971 Permeation of Refrigerants Through Elastomeric and Plastic Hoses “The effect of oil on refrigerant permeation was found to be relatively unimportant”. Now here is a study not so much concerned on the environment but rather simply reducing R12 refrigerant leaks. And all published studies show that R134a leaks more than R12. Clodic, D.,. Zero Leaks, 1996 “the estimated industry recharge prior to the conservationist activities was 1 every 3 years”, “In 1993, the replacement of refrigerant hose assemblies was reported on 21.1% of serviced vehicles. In 1997, the replacement of hose assemblies occurred on 11.1 of the service fleet”. What this report says is that years ago, with non barrier hoses having oil in the hose and using a larger molecule refrigerant (R12), that vehicles needed to be recharged often. And, prior to fleet use of R134a (pre 1993), that non barrier hoses in vehicles were replaced 21% of the time during a service repair. And, after the introduction of R134a with barrier hoses (post 1992) that the need to replace a hose was cut in half (1/2). This report does not say non barrier hoses are better, rather it says barrier hoses need to be replaced less often if at all. SAE Technical Paper 2005-01-2032, 2005 “the presence of oil had no effect on refrigerant emission with vapor in contact with the hose (inner diameter), AND, to determine the contribution of hose permeation vs. coupling emission. it was determined that the overall contribution of coupling (i.e hose connections) emission to the overall refrigerant emission of the assemblies was very small.”. So this report says having oil in non barrier hoses using R134a did not help to reduce leaks that much. And, hose connection points are not really the major source of leaks. Mines ParisTech, by Yu Yingzhong, HFC-134a Emission Modes, 2008 “According to the results of several tests carried out during this research work, the presence of refrigerant oil has only a modest effect on permeation.” “Therefore it is important to choose low permeation hoses. , which appear suitable for MAC systems.” So Wwest. Can you advise the forum of the factual scientific study the EPA is using to make their flip-flop-contradictory statement? What study(s), reports, papers, conclusive empirical data has the EPA provided to you directly, which is more conclusive of that presented by authoritative individuals, organizations, etc. ? Last edited by kuehl; 06-01-2013 at 08:21 PM.. Reason: coffee |
Nice references kuehl.
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
"Both the EPA and SAE are now on record stating that converting a Porsche 911 R-12 system to R-134a DOES NOT require switching to non-barrier A/C hoses."
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Banned
No, no - you're supposed to read between the lines and connect the dots. The EPA and SAE aren't *actually* on-record about Porsche hoses. Even though I assume that's exactly how wweird wrote it. They are on-record about something technical, no doubt. Something tangentially related to wweird's ideas about A/C.
"Both the EPA and SAE are now on record stating that converting an R-12 system to R-134a DOES NOT require switching to non-barrier A/C hoses.." Satisfied..??? |
Note: Caution about these document's use of the term: "Permeation". Permeation in our context, "oil permeation" might only mean saturate a substance, not nessarily migrate through a substance. Oil permeation of the inner surface of our non-barrier hoses might well prevent the follow-on permeation, migration, of refrigerants. There seems to be no indication that the refrigerant oils go beyond permeation of the hose inner surface, no loss of oil even in the long term. Last edited by wwest; 05-18-2013 at 11:12 AM.. |
Recreational User
WHY do we have to have another fight with this guy??? Can't you just ignore his posts? Do we need another piss and vinegar thread about A/C?
MODERATOR HAVE MERCY ON US ALL AND CLOSE THIS THREAD IMMEDIATELY!! |
So, Wwest. Question for you.
Assume its 90F outside. You have in your possession a Porsche 911 (78-89; SC or Car.) with a stock AC system (stock non barrier hoses, 2 condensers, etc) running either R12 or R134a. An AC technician has just confirmed for you that refrigerant level is to factory spec., the ac controls are working (thermostat turns off system when it should), vents blowing colder air than outside naturally. The AC technician also injected dye tracer, found no leaks, and then he inspected every AC component connection, and component, with an electronic refrigerant detector (heated-diode type) and has announced there are no apparent leaks. The system pressures are running 240 psi on the high and 30 psi on the low; we will just accept these numbers for the moment. You take the car out for a 1 hour drive, driving the vehicle as hard as you can handle with the AC running all the time (compressor is cycling on and off as the thermostat says it needs to). After the hour drive you immediately stop back to see the AC Technician. He quickly attaches a service gauge set and notes the readings with the engine running and compressor engaged, 260 high and 35 low. You turn off the engine and compressor. The deck lid is put down as far as it will go, you don't want to crush the hoses to the service set, you place thick moving blankets around the gaps between the deck lid and the body. 1) What happens to the high side and low side pressures during the 15 minutes or so that you and the AC tech are observing the gauges? 2) After the 15 minutes the AC tech takes out his black light and inspects every hose and component connection, and components as well. What does he see? 3) A moment after that the AC tech takes out his electronic refrigerant sniffer and checks the same joints and components. What does he observe? PS, if you decide to respond you don't have to quote this entire post (let's save on hosts memory and the annoyance of reposts), just answer the 3 questions. Thankyou. |
Many cars of this era have refrigerant pressure relief valves or "fuses". To go to that extra expense a system overpressure must have been expected to happen often enough to justify the added complexity and expense. Last edited by wwest; 05-18-2013 at 04:59 PM.. |
I see.
And you say the high side pressure would rise.. hmmm. How high? And, what about the low side pressure, what would happen to it? Let's assume the electronic detector is accurate for leaks as small as .25 (1/4) ounce per year. Last edited by kuehl; 06-01-2013 at 08:22 PM.. Reason: ounces |
Wwest is a JOKE, why do you do him the honor of a response? Let him rant, get embarrassed, maybe he will eventually go away?
Gary R. |
Okay, let's assume sensitive enough for our, your, purposes...then yes, in some circumstances you would detect leaking refrigerant at the "weakest link", as you have stated, the component most subject to system pressures beyond their design specifications. In your case it was the 350-450 PSI BOV. |
I find it difficult to become embarrassed when stating FACTUAL information.
Wwest,
How many threads are you going to post about your over pressurizing theory causing leaks. Yet you have never provided any data. Simple questions for you to answer for you peers. So answer the question Last edited by kuehl; 06-01-2013 at 08:23 PM.. Reason: time out thing |
