1977 911S; What kind of trailing arm do I have?
Hi,
Trying to determine what kind of trailing arm I have? The 77 "S" came with Turbo brakes and struts, but what about the trailing arms? Thanks for any help! |
JR |
There are 2 varieties of sway bar mounts - ball and the later bolt on. Not sure when the transition occurred - I think in '78 when the SC came about. CV joints are different too - went to 6 bolt rather than 4 bolt and 2 pins each.
-C |
JR |
Thanks for the replies.
My understanding is that the 77 "s" did come with the aluminum calipers, but not all had them, not sure why. |
I think you'll find that a '77 911 came with cast iron front calipers. They all had iron rear calipers. When the turbo was introduced in 1975, it used the aluminum calipers on the front.
There is some info in some of the books written about the 911 that is incorrect. JR |
The aluminum calipers were hit or miss. Only on S models, but not all. Not sure if it related to strut type (Bilstein, Boge, etc). Eric Shea @ PMB may know the specifics. My '74 had them, but I switched to the iron SC units as they stop better.
-C |
Oh, and the ARB console, clamps and bushings are different too. Quote:
'77 was a change-over or one-year-only thing in quite a few ways. Also the first year you're guaranteed to have a fully-galvanised body (as they hadn't used up all the non-galvanized roof panels until somewhere into the '76 model year... |
| All times are GMT -8. The time now is 11:22 AM. |
