-   -   pedal cluster 80 sc (http://forums.pelicanparts.com/porsche-911-technical-forum/750871-pedal-cluster-80-sc.html)
beany 05-19-2013 02:45 PM
pedal cluster 80 sc
With all the suggestions from this group, I was FINALLY able to get the cluster out. I ended up removing the bolt that attaches the brace to the master cylinder in the front area and was able to jiggle it out. Hopefully, now the fun part starts. Hope it goes in easier than it came out because I was a couple of minutes away from getting the saw out and sectioning the cluster brace. In the process the clutch spring came off. Will worry about that later. Thanks Beany
Nickshu 05-19-2013 06:32 PM
Yep you have to loosen it up at the master cylinder. Keep it loose when you reinstall, it makes it much easier. I came across this solution on the forum when I was trying to get mine out/in.
