1972 fuel pump options?
I have a 1972t with mfi. The fuel pump (located under the torsion tube) is shot. I have been searching the forums to get advice on non-OEM options. Does anyone have a simple answer? Thank you in advance.
John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver 1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green 1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet |
I sent my fuel pump to Fuel Injection Corporation 925.371.6551
Fuel Injection Corporation They did a great job Tom
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
GAFB
installing Zims replacement MFI fuel pump
Britt never updated the thread, but the car and fuel pump are running great.
Several BMWs |
How to resuscitate an almost dead fuel pump!
When I removed my non working fuel pump from the 72T MFI and hooked it up to a battery, all it did was hum a bit. On gptom's suggestion I called Fuel Injection Corporation. They offered to rebuild mine for $325. That was better than buying a new one. Then dtw pointed me to the post about the Zim option. While considering what to do, I took the following steps:
1. Soaked it for a few hours in my parts washer. 2. Sprayed Sea Foam penetrating oil in the pump while alternating connecting it to a battery to run it in one direction then the other. 3. Smacked it with a hammer. (it actually started to run when I did this) 4. Continued to circulate Sea Foam Oil through the pump while alternating the pump direction for short bursts. Remarkably, it is now working. When it finally does die for good, I will use one of the other excellent suggestions. Thanks Guys. John
Would it be a good thing or a bad thing to run the pump in reverse while it is assembled in a CIS car?
I don't have a comment on that. I have not worked on a CIS system, and don't know how the pump differs. If it is a non-working pump, you have little to loose. However, why not try everything I mentioned without reversing the polarity and direction of the pump first. I don't think the reverse direction was the key to my success. I believe it was the combination of penetrating oil and a hammer.
Best of luck. John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver 1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green 1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet Last edited by teachkenpo; 05-21-2013 at 05:53 AM.. Reason: spelling error |
I believe that the general consensus is that the best pump for an MFI system is an original OEM unit. The other non-original options end up making concessions in one way or another.
My recommendation would be to either pick up a rebuilt pump, or to have yours rebuilt. FWIW the current "OEM" offering from Porsche Classic has a terrible reputation and is apparently made in China (in addition to being hideously expensive).
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
