short legs - need clutch pedal help
I'm sure that I'm not the only one with this problem:
my legs are a little shorter and I have to pull the seat almost completely forward to allow me to fully engage the clutch.....not only does this put my face about 4 inches from the windshield, but it also causes big problems shifting into 2nd gear (lever hits the seat). I would like to extend the pedal backward somehow and cant seem to find an extension to attach. I guess a wood block duct taped to the pedal would work...but doesnt sound very safe. Any ideas ? (besides taking steroids or stretching my legs?) please be kind. |
Guest
Posts: n/a
One of the PO's of my first 911 had the same challenge. He drilled holes in the pedals and screwed wooden blocks to them. I only assume he attached the gripper/cover thingies for foot traction.
Mark |
Platform Sneakers
Now let's be careful here and not poke fun at the "little people" here. He's asking a serious question. Personally I say "you gotta love them midgets".
Dan O |
on the last one i did for a real short lady, i made a copy of the metal pedal pad from 1/4" plate, curved it like the original and spaced it out with a couple of pieces of tubing that bolts went thru. hang a pad on it and go.
I had this problem with my 914 race car after I installed a removable steering wheel and I added 1 inch thick lexan blocks under Sparco pedal attachments. You can see a picture (#21) in the article I have on how I setup my race car on the PP site here in the 914 section. You'll have to drill at least 2 holes for each pedal to bolt it all together, but it works great! Good luck.
I'm in the same camp - I like to call it "vertically challenged". I noticed at the Autox this last weekend that I was crowding the wheel just a little bit - and I like to sit more upright.
I'm planning on adding about 1/2" when I put aluminum track pedals on - I'll fabricate spacers out of aluminum stock or something. Might help with heel and toe too.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
MN
Hi Tim,
Just wanted to add that when my Tim sat in your car (and he is almost 6') he also had a stretch getting the clutch pedal pushed in completely. Sounds like John Walker's suggestion could work for you. Good luck!!
87 930 Blk/Blk |
I'm confused....I'm no towering inferno and I can use the clutch just fine without having the seat way up. Are you sure your clutch is o.k? Maybe your seat's vertical adjustment is off or something? Mine is an 85 also, so maybe you ought to go sit in another of our vintage just to make sure your o.k. mechanically.
![]() 85 Carrera Targa (sold!) 03 Dodge Ram 1500 HEMI |
I've got the electric seats with the 2 adjustable switches and have tried a bunch of different settings. My clutch doesnt need to go all the way to floor to engage, but I prefer pushing it to floor just to make sure.
stats - 5'8" 165 lbs 21 " inseam ![]() just kidding, 30" inseam. I'm going to add an metal extension on with bolts/nuts and back my seat up a bit........looks like I have a Saturday project now ! |
I am your size drive an 84 ......
Is the floor board in place ? Maybe there is no floor board and the clutch is ging down to far ....
Got Boost?
I have the same problem, I used a rubber sanding block from pepboys. Drilled a hole on the pedal and bolted the block with the curvature facing the driver.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- |
Senior Member
Hello
Hint: Pre 76 pedals are adjustable from the factory. Mostly you can get some 20-30mm out or inwards. Grüsse |
I am glad someone else has to problem too, I have been adjusting the seat in my new ride for weeks now and thought I was nuts
Brandon 1988 Porsche 911 Coupe http://www.tidalfish.com/bcw/porsche/pc.jpg If you like fishing, click below, you will love the site! Great boards like here! http://www.TidalFish.com |
