| Registered |  alternator wiring
			I know, I know, mark all your wires before disconnecting... but I just rebuilt my 77' 3.0, and my wiring notes went bye bye, after 6 months of playing with the rebuld. Can anyone tell my which wire goes where on my alternator?   I think #1 is RED, 2 is BLUE? and 3 is BROWN. 4 is N/A? But I still have a BLACK wire, and the ground stap... Grond strap from housing to case? Thanks guys!
				__________________ Pete Fredericksburg VA USA 74 EURO Carrera (right hand drive) 82 Targa (left hand drive) | ||
|  07-20-2002, 09:43 PM |
| Registered |
			anyone?
|  07-21-2002, 07:45 AM |
| Registered |  My alternator looks different on my
			79SC but I'll try to help since I just removed mine yesterday.  I don't see any markings on your alternator but if you can find them, the sequence is : Blue wire on +61 Tan wire on D- next to the +61 connector Double red wire (10mm nut) on B+ (on other side of +61 connector) Three small tan wires on D- next to the other D- (there are two D- connectors on my alternator). I'll bet one is what you are calling case ground. My DF connector is black and is a push on that connects to the plastic piece at the bottom. There is no dedicated case ground wire, but based on the attached article, D- also connects to the alternator frame. The alternator troubleshooting article is attached. Maybe this will also help you figure it out. By the way, I did a hand drawn sketch years ago and scanned it into my computer. Good Luck. http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_electr_main.htm Click on alternator, then alternator troubleshooting guide in the header. | ||
|  07-21-2002, 07:53 AM |
| Registered |
			I took another look and the D+ , B+ , and +61 connectors all have insulators under them. The D- does not, so is grounded to the case. I verified this with my ohmeter. Yours should be the same, now you just need to distinguish the above three. | ||
|  07-21-2002, 08:04 AM |
| Registered |
			I see a 61, and I see a -, and I am sure of the B+, but I need to look again for where the black goes... Thanks for your help.
|  07-21-2002, 08:12 AM |
