I need a new plastic clip that holds the rod in the door lock release mechanism.
It is worn out and every time you pull on the interior door handle it jumps out. I do not see this exact part listed. The only part I see is the part for the door handle itself. This part has a molded piece that keeps the rod secure. Any idea of where I can get this part? I have it temporarily fixed with a piece of plastic tubing. If the rod was just a little longer it would not pull out. ![]() Just another aggravation, I just finished installing the door stay repair parts and replacing the cardboard door panel. Then this started happening. Thanks, Scott 78 Black Targa |
I just bought this one a few weeks back for my 82 but it looks different than yours.
Pelican Parts - Product Information: 993-531-563-00-M100 Walt
Walt 82SC 3.0 81SC 3.6 |
Yep that's the same one I see available and is the one that goes in the door handle.
I guess it would work, but would be missing the plastic piece that hold the rod in place and from jumping out. I may have to try that for now. Thanks................ Scott |
