-   -   How to remove clutter from 993/964 engine compartment (http://forums.pelicanparts.com/porsche-911-technical-forum/751960-how-remove-clutter-993-964-engine-compartment.html)
rsscotty 05-24-2013 03:09 PM
A hard charging slide valve engine with short gears too.
http://forums.pelicanparts.com/uploa...1369433163.jpg
http://forums.pelicanparts.com/uploa...1369433187.jpg
http://forums.pelicanparts.com/uploa...1369433207.jpg
http://forums.pelicanparts.com/uploa...1369433255.jpg
redturbo911 05-24-2013 03:28 PM
Impressive. Nicely done.
Bill Verburg 05-24-2013 03:44 PM
Nice!,CoP too, how about providing the full specs?
Mahler9th 05-24-2013 08:08 PM
I want that for my engine.
911dean 05-24-2013 09:00 PM
That is just awesome. Please tell us more.
Dean
jstyer 05-24-2013 09:03 PM
So much lust... Awesome job guys. And +1 on sharing all the specs!
Trophy 05-24-2013 09:47 PM
+1 specs on the COP, lots of details.....
911Freak 05-24-2013 10:15 PM
Drooooooollllll!
Details!?
CoP?
rsscotty 05-24-2013 10:50 PM
993
Thanks guys.....
Here are a couple shots of our exhaust setup. I'll fill in the details on the engine later.
http://forums.pelicanparts.com/uploa...1369460979.jpg
http://forums.pelicanparts.com/uploa...1369461007.jpg
timmy2 05-24-2013 11:41 PM
Note to self: DO NOT drive north to Rothsport. DO NOT drive north to Rothsport..... :)
redstack 05-25-2013 05:11 AM
OH man that must be a million dollars worth of perfection.
redstack 05-25-2013 05:12 AM
How about video of it running?
EMBPilot 05-25-2013 07:30 AM
amazing work
redturbo911 05-25-2013 08:37 AM
+1 on video of it running.
shbop 05-25-2013 09:50 AM
Sweet!
Erick 05-25-2013 11:45 AM
How about a glimpse at the dyno plot? Or was this project for the express purpose of removing clutter? :)
HiWind 05-26-2013 03:01 AM
Are we getting more?! I 've paused the F1 incase you update ;)
Raleigh993 05-26-2013 05:17 AM
That is a work of art.
RideSober 05-29-2013 01:21 AM
Damn, that baby is looking more sexy than Megan Fox...:eek:
Sweet :D
Nine9six 05-31-2013 04:03 PM
Sweet :D
I'd crawl over a pike of Megan Fox's just to blip that throttle. Well maybe not a pile...:eek:
rsscotty 05-31-2013 07:45 PM
Dyno sheet finally made it to my laptop.
http://forums.pelicanparts.com/uploa...1370054579.jpg
rbogh901 05-31-2013 08:18 PM
very little clutter...that's how i would like my dyno sheet to look too.
Trophy 06-01-2013 08:42 AM
Ok, now you have to give us the full specs of this engine.
What heads is this running? What Cams? Details on the COP?
Also interested, did you take a reference off the cam for timing?
rsscotty 06-01-2013 10:19 AM
Engine specs
This engine runs DTA S60 engine management, wasted spark, no sync. sensor.
Bosch TPS used as load sensor
MAP sensor for baro comp
Bosch air temp sensor
993 RS flywheel 60-2 with 993 Bosch reference sensor
Four 3 channel ignitors
Omega high comp. pistons
Elgin cams
Proprietary cast aluminum heads
Proprietary 2 pin connector COP Intake uses Early RSR plug hold down tabs
Exhaust uses no hold downs, COP screws onto the plug, tops push on like stock ones
Rothsport stainless headers with our own design v-band secured connector pipe
GT 3 Cup muffler with factory engine bracket and straps
We have another build like this engine in a 964 that has slides with our own design screw in stacks that makes 436 hp. This one is wasted spark also.
http://forums.pelicanparts.com/uploa...1370107044.jpg
http://forums.pelicanparts.com/uploa...1370107081.jpg
http://forums.pelicanparts.com/uploa...1370107108.jpg
AOW162435 06-01-2013 12:28 PM
Mother of Pearl.
Andreas
rsscotty 06-01-2013 07:29 PM
More intake options
Rothsport GT3 carbon intake. It weighs 6 lbs. compared to the metal factory @ 12 lb.
http://forums.pelicanparts.com/uploa...1370140023.jpg
http://forums.pelicanparts.com/uploa...1370140047.jpg
jstyer 06-06-2013 11:05 AM
Now all we need is a sound clip of her running :)
JmuRiz 06-06-2013 11:24 AM
Fancy stuff, wish I was rich :D
rsscotty 06-06-2013 12:57 PM
Sound clip
OK...this was our first prototype 3.9 engine for Jeff's RSR on the slide valve system, and air filter setup.. We have about 40 more horsepower now, with newer engine management and quite a few new developments. The exhaust turn outs are to meet the 103 db limit at the local track where we test.
Rothsport Racing '97 Porsche 993 RSR Strafing Runs - YouTube
andybullen 06-06-2013 01:15 PM
oh my .....
rsscotty 06-06-2013 07:10 PM
Road test
It is even more amazing when you are there live!
jstyer 06-07-2013 08:46 AM
Scotty, does the car in the video have the gt3 cup exhaust?
rsscotty 06-07-2013 10:15 AM
Exhaust
No, this engine had the Magnaflow muffler and older version headers we used in the past. Our new headers and GT3 muffler are on the car now.
rsscotty 06-07-2013 03:28 PM
Dyno video 3.9 435hp Rothsport Slide Valve
DSCN1021 - YouTube
rsscotty 06-07-2013 03:35 PM
Rothsport 3.8 Yellow 993 ENGINE DYNO
DSCN1402 - YouTube
Synchro Joe 06-08-2013 09:41 AM
Oh chit! I want one, but of course would have to sell all the Enron stock.......oh wait never mind.
kkswow12 09-09-2017 01:30 PM
wow wow wow
been looking for itb's for mine, this looks even better...wow...
HiWind 12-04-2017 04:45 AM
Originally Posted by rsscotty (Post 7460810)
Thanks guys.....
Scott I still come back to this thread to review once in a while .. its just lovely.
I see in this pic of the exhaust there's a massive gap between the valve covers and the exhaust - is that to increase cooling/decrease exhaust to valve transfer? Is that possible in a NB car or only cos you have those mamma hips on the GT2 body?
Or am I wrong and there isn't much to worry about from the collector pipe to valve covers/ig wires, and you just did that for the size of the GT3 muffler?
rsscotty 12-04-2017 12:23 PM
That engine was one of our early builds a few years back. We are using our own design headers now and we do use a heat shield to protect the valve cover and coil on plugs.
http://forums.pelicanparts.com/uploa...1512418985.JPG
HiWind 12-04-2017 12:45 PM
super thanks for that - do you sell those headers/exhausts?
