-   -   Dumb CIS question (http://forums.pelicanparts.com/porsche-911-technical-forum/752062-dumb-cis-question.html)
Specmiata 05-25-2013 07:45 AM
Dumb CIS question
Messed up fuel line order on 1973.5 t. If I understand correctly, there is no "firing order" from the fuel distributor so fuel lines do not necessarily correspond to a particular cylinder. I am correct in this assumption?
ossiblue 05-25-2013 07:57 AM
Yes, you are correct. Route your lines the most efficient and least restrictive way to each cylinder/injector.
Specmiata 05-25-2013 08:10 AM
Thanks!
James Brown 05-25-2013 10:45 AM
that's a good CIS question, will help many in the future
