Wew Wew is offline
SC Mutt
Wew's Avatar
Targa bar paint or strip for chrome look
Hi all, I have my 1978 sc. Black paint on targa bar has seen better days. I am in the process of a restore on the car and am at a cross roads for what look to go for. I know it's a personal choice but would love all input from whatever perspective and for whatever reason. I am including pictures although lighting is not the greatest in my garage. I did purchase the h4 lights as I like the look. I went for the chrome rings but could purchase a pair of black rings and have painted when I paint the car. I am sticking with the original color which I like a lot.
1978 911 sc copper brown metallic.
Thanks,
Gary
Old 05-25-2013, 07:36 PM
porwolf's Avatar
It looks like your Targa bar was originally not painted black because your window trim is bright aluminum. My "79 Targa came with the silver brushed stainless steel Targa bar as standarg equipment. The black trim in those days cost extra. In the eighties that was considered cool and some folks painted their silver brushed Targa bar black. In that case the black paint should come off rather easily. You could try paint remover in a small spot and see what happens.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-25-2013, 07:59 PM
I literally started this today! I am stripping it. If I don't like the look I will have a nice clean base to paint.
Old 05-25-2013, 11:25 PM
I have seen a few 1978 Targas with the bright trim on the front and rear window, but with black targa bar and quarterlights on the doors. It seems that Porsche got confused. Mine is a 1978 Targa with the sport package, so Fuchs, whale tail, etc and should all be black, but my front and rear window trims are bright and I am pretty sure they are original.
Old 05-26-2013, 01:42 AM
grateful user
don gilbert's Avatar
here is my painted to match bar.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-26-2013, 04:40 AM
Since you asked, my first suggestion is make it the way the factory made it. You did not mention how it came stock, but I assume it was black.
If that is not persuasive enough, than I suggest that whatever way you go, make the whole car match it. So if it you go shiny or black on everything which is more costly/hassle to do? For instance, the trim around the light lenses black? Engine grill?
Lastly, you have a very cool color and I think the black on everything would look better -- I think chrome looks good on the 1970s signal colors (green, orange, yellow) but that black looks better with your more sophisticated color. Either way you will have a great car, enjoy!
SCOTT
1971 911T targa
Old 05-26-2013, 06:27 AM
bcheney's Avatar
Targa bar
If you haven't looked at this thread....do so. I think keeping black is the way to go for your car...However, aluminum look is cool to.
Ultimate Targa Thread!
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 05-26-2013, 08:03 AM
Ok, I don't want to hijack this thread. But I did the stripping this afternoon and here are the pics. Decision will factor on how even I am able to get the finish on the metal.
Old 05-26-2013, 05:29 PM
MANichols1's Avatar
Figured I'd give the stainless look a try. Before and after...
'85 Targa
749R
Old 05-26-2013, 06:04 PM
Nico911's Avatar
Wow, ''after'' looks good.
1985 911 Targa (sold)
2001 996 Twin Turbo
Old 05-26-2013, 06:09 PM
porwolf's Avatar
I think the brushed stainless Targa bar looks good as it was originally intended: To stand out and not hide under black paint. But I am prejudiced, my 79 Targa came like that. But Buzzi endorsed it also:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-26-2013, 06:51 PM
Wow, Awesome transformation. Do you have more pics of that car?
Old 05-26-2013, 07:59 PM
I would recommend keeping it metallic, especially as you have brightwork around windows, on wheels and chrome door handles. It looks great with unusual colors...
porwolf's Avatar
For your consideration. Here is my all original 1979 Targa without the black out option group:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-26-2013, 08:12 PM
Now that I have I stripped do you guys have any guidance on evening out the stainless steel finish?
Old 05-26-2013, 11:10 PM
porwolf's Avatar
Isn't your stainless steel Targa bar finished with a brushed surface? That was the original finish for your car I understand. Raw stainless steel does not need any surface treatment. Why don't you keep the brushed finish as is?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-27-2013, 11:59 AM
Wew Wew is offline
SC Mutt
Wew's Avatar
Here it is. Stripped polished and reinstalled... I will put a couple with the bar pained for comparison. Lighting is not the best in the garage but I hope you get the idea. Please give honest input.
Thanks,
Gary
Old 05-27-2013, 04:28 PM
MANichols1's Avatar
Stripping the paint was easy. Aircraft stripper works wonders. To get the finish even, I started with 215 grit sandpaper and moved to 400 - 800 - 1000-green pad. Honestly, the finish is a bit more polished than I'd prefer. I like the rough stainless look over the polished bar look. I've actually, roughed mine up a bit to my liking. I wanted to match the new finish on the wheels. So far, everyone seems to like it. Targas need to be different to stand out!
'85 Targa
749R
Old 05-27-2013, 05:39 PM
Thanks,
Gary
Looks good!
Old 05-27-2013, 06:45 PM
I think I am going to keep it bare. The bar looks really good on its own.
Would you recommend stopping at 800 grit to keep from going to far towards a polished look?
Thanks!
J
Old 05-27-2013, 06:47 PM
