75 911S Electrical Gremlins
Need an electrical guru close to northeast NC. Any recommendations appreciated.
Old 12-13-2012, 07:47 AM
pete3799's Avatar
What's the problem?
Or do you not want to deal with it?
Might be an easy fix.
Pete
79 911SC RoW
Old 12-13-2012, 07:58 AM
Hi Pete
Thanks for responding.
I have a short affecting the fuel pump. When I try to bridge the fuel relay (#30 to #87a) the fuel pump will not run. When I put 12 volts to it, it runs. The starter runs in key position 2 rather than position 3. This happened before and I replaced the ign switch, it then ran fie for a while. When I check the 3 fuses in the engine compartment they show continuity with ground. At the fuel relay #87a shows continuity with ground.
Any suggestions would be appreciated.
Thanks JFD711
Old 12-13-2012, 03:48 PM
