-   -   Is it possible to change the sender unit without removing the tank? (http://forums.pelicanparts.com/porsche-911-technical-forum/752779-possible-change-sender-unit-without-removing-tank.html)
Tony (guest) 05-28-2013 12:42 PM
I have the oddball 1972 911 mentioned in this article. Is it possible to change the sender unit without removing the tank?
Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Oil Level Sender Replacement - 911 (1965-89) - 930 Turbo (1975-89)
Nick at Pelican Parts 05-28-2013 12:42 PM
The oil tank is probably going to need to be removed first
- Nick
proffighter 05-28-2013 04:22 PM
No way on a 930, but if tank lowered it is possible...
