-   -   How does the the pedal assembly communicate with the engine? Cable ? How does that attach to the pedal assembly (http://forums.pelicanparts.com/porsche-911-technical-forum/752819-how-does-pedal-assembly-communicate-engine-cable-how-does-attach-pedal-assembly.html)
Wigger (guest) 05-28-2013 02:07 PM
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Rebuilding your Pedal Cluster - 911 (1965-89) - 930 Turbo (1975-89)
Nick at Pelican Parts 05-28-2013 02:07 PM
Yes there is a cable that attaches the throttle pedal to the engine's throttle linkage. The pedal side of the cable is attached similar to the clutch. Look at tech procedure #9
- Nick
SilberUrS6 05-28-2013 03:40 PM
Wi-fi.
Ronnie's.930 05-28-2013 03:49 PM
Yes indeed . . . a fiber-optic cable (and/or wi-fi, dependant on the year model, as mentioned above).
