-   -   AC Blower runs well but only when directly connected to battery, what might be the problem? (http://forums.pelicanparts.com/porsche-911-technical-forum/752838-ac-blower-runs-well-but-only-when-directly-connected-battery-what-might-problem.html)
pit 05-28-2013 02:41 PM
AC Blower runs well but only when directly connected to battery...same happens with cool air blower motor...fuses are ok...how can I see the wiring diagram for my 911 1987 Carrera...what might be the problem?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Air Conditioning on the 911 - 911 (1965-89) - 930 Turbo (1975-89)
Nick at Pelican Parts 05-28-2013 02:41 PM
You either have a bad blower motor switch or more likely a bad blower motor resistor. This resistor drops the current to the motor so you can change the motors speed. Try replacing that first
- Nick
wwest 05-28-2013 02:51 PM
Assuming you are talking about the evaporator blower there is a voltage limiting resistor module that limits the blower voltage in the lower speed control positions. But these are bypassed in the high speed position.
BUT...
The "module" also has an overheat CB should the resistor pak begin to overheat. If the CB fails "open" the blower will not run.
Worth an inspection, mounted in the evaporator airflow inlet behind the passenger footboard.
Sometimes fuses are good but not tightly clamped by the holder.
ghiaholic 05-28-2013 03:01 PM
I had the same thing. After tearing my hair out chasing the entire circuit with a tester it turned out to be that the yellow wire out of the relay in the smuggler's box was disconnected. This goes to ground when the starter is not engaged - you need continuity to ground with this wire for the blower to run. Reconnected the yellow wire (PITA working under the dash behind the vents!) and it runs like a champ.
